leaking antifreeze - Mustang Evolution
Old 12-11-2012, 11:51 AM   #1
Region: Iowa
leaking antifreeze
So the other day my car overheated going down the interstate. So I pulled over and let it cool off once it was back down to normal I started it up and started driving it just trying to get to the next exit. But it never got hot again so I finished my drive home. Checked the antifreeze level and it was a little low so I added some. Then today I took it for a drive and my temp gauge never warmed up at all after about a 20min drive. when I got home I popped my hood and there was a lil bit of antifreeze under where the top hose connects to the engine but doesnt look as if the hose connection is where it is leaking. I have no idea whats going on any ideas??
brettthom1422 is offline   Reply With Quote
Old 12-11-2012, 12:29 PM   #2
1slosix's Avatar
could be a sticking thermostat...cheap enough to swap and see if anything changes. it could be causing fluid to back up
carving corners like a boss
Old 12-11-2012, 12:50 PM   #3
Region: Iowa
I had just changed that last weekend because my old one was stuck open.
Old 12-11-2012, 01:04 PM   #4
1slosix's Avatar
did you replace the gasket?
Old 12-11-2012, 01:42 PM   #5
Region: Iowa
Yes i did after cleaning off the area where the old gasket was
Old 12-11-2012, 01:48 PM   #6
tc x 4's Avatar
Take it out and drop it in really hot water and see if It's working. New ones can be defective too.
Old 12-11-2012, 03:03 PM   #7
Region: Iowa
Alright I'll give that a shot tonight and let everyone know what i find out
Old 12-11-2012, 05:33 PM   #8
NewMtang's Avatar
I had a problem with my daily driver. Not a Stang. As long as I didn't go on the interstate, it didn't leak. The pressure from the higher speeds caused a leak on the head gasket. It was such a small leak that if any fluid leaked it didn't form a little leak pool.
Old 12-11-2012, 10:25 PM   #9
tc x 4's Avatar
With a head gasket leak, It was probably going in your oil or out the exaust.
Old 12-11-2012, 11:47 PM   #10
Rosco's Avatar
Do a pressure test on your coolant system for leaks. Where did you buy your thermostat? If its autozone I'd chuck it and go buy oem. A cheap one can stick too.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 12-12-2012, 08:25 AM   #11
Region: Iowa
Well i checked the thermostat last night it works fine in water. And ik there isn't antifreeze in my oil so i hope it's not a head gasket. But yes i did get it from AutoZone. Iv never done a pressure test is it hard to do? How do you do it?
Old 12-12-2012, 11:11 AM   #12
sixxerstang's Avatar
Think maybe you could have busted the thermostat housing?
sixxerstang is offline   Reply With Quote
11:45 AM
