Transmission fluid - Edge 2001 - Mustang Evolution
Old 12-12-2012, 05:38 PM   #1
sam62893's Avatar
I have a new edge 2001. I was wondering if anyone knew how to change the transmission fluid and which one to buy. My transmission feels a little funky right now and a buddy of mine recommended I change the transmission fluid. I got the car at 89K miles, it now has 108K never changed the tranny fluid
Old 12-12-2012, 07:23 PM   #2
kickerofdoom's Avatar
Take the pan off and let the fluid drop
Old 12-12-2012, 07:35 PM   #3
sam62893's Avatar
Okay, which one is the trans fluid pan? I don't wanna unscrew the wrong bolts and end up unscrewing the wrong pan xD and is there like a gasket around the pan that should be replaced after the whole process?
Old 12-12-2012, 07:39 PM   #4
maples. j's Avatar
Yes there is a gasket tht lines the top of the pan and you'll meed to change that when you drop the pan the have a bad habbit of stretching and not going back in and you also need to take a magnet and get all the shavings outta the bottom of the pan
maples. j is offline   Reply With Quote
Old 12-13-2012, 02:03 PM   #5
1slosix's Avatar
if you're gonna do a service change go ahead and pay $15 for a new trans filter...usually when you buy one you get the new gasket in the box so that's a good thing.
carving corners like a boss
Old 12-13-2012, 02:46 PM   #6
JetLife 01GT's Avatar
Is your transmission automatic? I always hear that on automatics when you change the fluid with 100k+ miles the transmission usually begins to slip about 5-10k miles later.
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-13-2012, 02:49 PM   #7
sam62893's Avatar
If I can find one of those, it would be good and I think I'll do that. And yes it is an auto. But there's my problem. The tranny is already slipping. From first to second it jumps if you don't go super slow
Old 12-13-2012, 02:53 PM   #8
Get a jmod and add seafoam trans tune
Old 12-13-2012, 03:09 PM   #9
1slosix's Avatar
only when you use crap fluid and don't replace the filter while you're in there...swap a qrt of fluid with a bottle of lucas stop slip and you're set if you're worried
Old 12-13-2012, 03:12 PM   #10
Has the tranny been slowly getting worse or did it all of a sudden begin to start slipping? Also you say you it jumps from first to second so you have to drive slow. Are you sure it's not shifting hard? Shifting hard can be another issue besides ur tranny. Just want to be sure before u replace the fluid man
2001 GT
Old 12-13-2012, 03:15 PM   #11
1slosix's Avatar
even if the issue at hand isn't fluid related it's still a great thing to change out at his mileage...better now then later i say
are you throwing a CEL?
Old 12-13-2012, 07:13 PM   #12
You can use Mobil1 Automatic transmission fluid for the T5 transmission.
You can use Amsoil 80-90W for the differential. The differential fluid may need to be changed a few times with some cheap fluid if you find it blue/gray. Once clear, put quality fluid like Amsoil & Ford Motorcraft XL3 LSD Friction Modifier Gear Oil Additive won't hurt.
Old 12-13-2012, 08:13 PM   #13
sam62893's Avatar
What's a CEL? Yeah, I guess I'll change the tranny fluid, better now than never. Well the car sort of jumps I guess trying to get out of first gear, it's sort of like someone who doesn't know how to drive a standard and jerks the car changing gears. Are those gasket/filter kits available at autozone or oreilly's?
So you're also saying I have to change my fluid a couple of times to get it right?
Old 12-13-2012, 09:21 PM   #14
Berry_Eggo's Avatar
Mines shifts pretty hard too, from first to second ?
Berry_Eggo is offline   Reply With Quote
Old 12-13-2012, 09:55 PM   #15
maples. j's Avatar
Ya I thought mine was the tranny to it. Felt like it was shifting hard then a week later my rear end fell apart this acutally was just 3 days ago on putting a new one in it this weekend goin to a gt rear end though
Old 12-13-2012, 09:57 PM   #16
Berry_Eggo's Avatar
Fell apart how? What parts ?
Old 12-13-2012, 10:13 PM   #17
maples. j's Avatar
I went to back out of the parking lot and went from reverse to drive and heard a big bang I thought I was the the tranny but the driveshaft still turns so it has to be the rear end and I really don't know what broke in it I'm just using this oportuninty to change to an 8.8 with 3:73 and alot of the time its easier to just change the whole thing
Old 12-13-2012, 10:28 PM   #18
maples. j's Avatar
I let you know tommrow though what actually broke haven't had the chance to look yet
Old 12-13-2012, 10:35 PM   #19
1slosix's Avatar
CEL= check engine light
the kits are available at any autoparts....and the jumping could be fluid related, torque converter related, solenoid related, etc....start with the cheapest and work your way up...and you'll only need to do it once not multiple times
Old 12-14-2012, 06:27 AM   #20
Berry_Eggo's Avatar
Ok thanks !
Old 12-14-2012, 01:02 PM   #21
sam62893's Avatar
Ohhhh nahh, my check engine light has never turned on. I feel like the tranny is loose, or the fluid sucks. Thanks, I'm gonna go pick up a kit and replace the fluid, if that doesn't work I'll try out what you told me and go from cheapest to most expensive problem. Thanks everyone
Old 12-14-2012, 04:40 PM   #22
maples. j's Avatar
Tommrow the stang is back and with a gt rear end..... can't wait
Old 12-14-2012, 09:19 PM   #23
1slosix's Avatar
did you have them up the gears in the GT rear while it was out of the car or did you keep the 2:73 gears in it?
Old 12-15-2012, 07:56 AM   #24
maples. j's Avatar
Gt has the 373 gears in it doesn't it? Cause I was looking it up and thts what I kept finding
Old 12-15-2012, 08:52 AM   #25
No v6 and gt have 3.27 gears gt have a tlock and 8.8 rear end
Old 12-15-2012, 09:20 AM   #26
maples. j's Avatar
Learn so.Ethan new every day lol
---------- Post added at 10:20 AM ---------- Previous post was at 10:19 AM ----------
Something
Old 12-15-2012, 09:35 AM   #27
Bongadier's Avatar
What gears does an 05 roush come with ... No stages just basic roush....
Bongadier is offline   Reply With Quote
Old 12-15-2012, 12:09 PM   #28
1slosix's Avatar
what year is the rear out of...and can you find out the vid of the original car?
in a 99-04 v6 or GT yes...but in sn95's its a bit more tricky...v6's had 2.73s...and GT had 3.08's for autos and 3.27s for 5 speeds
i just wanna make sure he is calibrated for gears if the rear didn't come out of a 5 speed gt
Something
Old 12-15-2012, 10:12 PM   #29
maples. j's Avatar
It's a gt outta a 95 and I just got done with the first test drive it has a little more take off but I don't have abs anymore
Old 12-15-2012, 11:26 PM   #30
1slosix's Avatar
what did they recalibrate the speedo for? a 5 speed GT rear or an auto GT rear? just curious since sn95's had a couple options that NE's didn't
Old 12-15-2012, 11:29 PM   #31
maples. j's Avatar
I haven't ajusted the Speedo yet I changed the rear end myself
Old 12-15-2012, 11:37 PM   #32
1slosix's Avatar
ok what you'll want to do to be on the safe side is to check the gearing yourself...they said 3:27s and it may be...but it could also be a 3:08. If you wanna check it without popping the cover off and having to fill it again..just to be safe
-jack up the back end
-mark the driveshaft with a marker on the bottom
-spin one of the back wheels by hand slowly one full rotation
-as you spin the wheel count the times the mark makes a full turn on the driveshaft
it's simple to read out
just under three turns 2:73
right at three turns 3:08
about a quarter past three turns 3:27
so on and so forth...glad your car feels peppier...it's always a nice upgrade
Old 12-15-2012, 11:59 PM   #33
maples. j's Avatar
Ow ya it's my first domestic project all others have been Hondas lol and thanks for the tip next mod is cai
---------- Post added at 12:59 AM ---------- Previous post was at 12:56 AM ----------
Change out was a pain though never wanna do tht again lol
Old 12-16-2012, 12:04 AM   #34
1slosix's Avatar
lol it's not the worse mod you can do at least the swap is straight forward...
Old 12-16-2012, 12:14 AM   #35
maples. j's Avatar
Ya except for the brake lines because I had to take them off of the new rear because I already had all of the and they ran different not to mention the new didn't have abs so now my abs light stays on
Is Transmission fluid flush necessary?? jmpark527 2005-2010 Mustang GT 11 10-04-2017 07:43 AM
TSB Transmission Fluid Change UPDATE pcarman 2011-2014 Mustang GT 11 01-10-2012 03:41 PM
Transmission fluid Siendly22 General Car Discussion 8 01-04-2012 06:32 PM
Manual Transmission Fluid Napoleon85 2011-2014 Mustang GT 6 11-15-2011 03:47 PM
Change Transmission Fluid pcarman 2011-2014 Mustang GT 11 10-01-2011 01:27 PM
04:22 AM
