Lowering - Mustang Evolution
Old 12-16-2012, 11:26 AM   #1
V6in's Avatar
Lowering
How much should I lower my car ? I have 18x9 tires and wheels in front and 18x10 in back with 1 in wheel spacers in back.
V6in is offline   Reply With Quote
Old 12-16-2012, 11:51 AM   #2
Venomouz831's Avatar
1.5-2'. How low do you like
)02 Gt, Founder of WE2G
Old 12-16-2012, 12:01 PM   #3
V6in's Avatar
I'd like about maybe an inch of wheel clearance or so. I also think I want the back up higher than the front.
Old 12-16-2012, 12:04 PM   #4
Go to search bar and there you will find many of these threads and what kits people are running
Old 12-16-2012, 12:20 PM   #5
V6in's Avatar
Will these fit my car ?
Old 12-16-2012, 12:32 PM   #6
Yes they will. They sell those on eBay for like 100 bucks
Old 12-16-2012, 12:36 PM   #7
1slosix's Avatar
If those are gt springs youll have to cut them thanks to the spring rate. There are about a half dozen lowering threads from the last month or so...feel free to search them and see what has been used. Whether you buy springs or cut your stockers we will help out where we can.
carving corners like a boss
Old 12-16-2012, 12:38 PM   #8
V6in's Avatar
Saw these on CL for $80 ill find out if they're for a gt
Old 12-16-2012, 02:36 PM   #9
V6in's Avatar
The guy said they're for both ? Does it matter ?
Old 12-16-2012, 05:31 PM   #10
1slosix's Avatar
Yes...they will fit both but GT springs have a higher rate for the weight difference... so the drop isnt the same which is why i said they may need cutting
Old 12-16-2012, 08:42 PM   #11
austinknoll's Avatar
I have GT springs on mine and I love them. The measurement for how low it will go is from a GTs weight. Since the v6 is much lighter than the GT, it might not lower it as much as a GT. the rear will be the same but it won't lower it as much in the front. For example if the springs lower a GT 1.5 in the front. It would lower a v6 1.2-1.4. There really is not that much of a difference
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 12-16-2012, 09:51 PM   #12
V6in's Avatar
Ok thx that helps a lot lol
Old 12-18-2012, 04:54 PM   #13
Project Pony's Avatar
I ran 1" wheel spacers in the rear with a 1.75 ish drop....couple of speed bumps or inclines and buy buy tires. I sliced em both to hell on the fenders. So the spacers were given away.
I would check your clearences before driving after getting everything together. You could also have your fenders rolled to prevent any issues with steep inclines.
Im not a fan of wheel spacers, I just bought a wider wheel and cut out the middle man.
[SIGPIC][/SIGPIC]
03:24 PM
