Turbos - Mustang Evolution
Old 12-19-2012, 08:25 PM   #1
Xaperez100's Avatar
Turbos
Does anyone know what all I would need to install two turbos in my 00' v6??
Xaperez100 is offline   Reply With Quote
Old 12-19-2012, 08:38 PM   #2
kickerofdoom's Avatar
New rear end,fuel mods and custom piping
Old 12-19-2012, 08:56 PM   #3
Xaperez100's Avatar
Rear end meaning? Tires? Or?
---------- Post added at 08:56 PM ---------- Previous post was at 08:56 PM ----------
I wouldn't need new tranny? Gears? Clutch? Throw out bearing?
Old 12-19-2012, 09:05 PM   #4
Twin Turbo? The only reason to get a TT is to run crazy boost. You are going to need a built motor from the bottom all the way up. Then you need a better 31 spline rear axle, if you plan on launching hard you should get a 9 inch rear diff. A new clutch is also a must have for that much power, stage 3 would be the best to get. That's just to prep it for the TT, you're going to need to get the entire kit and install all the necessary components to make it work. You also need a custom dyno tune on top of all that.
If you are going TT you are going to need extremely deep pockets.
Old 12-19-2012, 09:19 PM   #5
Xaperez100's Avatar
Yeah I knew there would be a lot of stuff.. I was gonna save up. But what would be better? And cheaper? Supercharger? Or TT?
Old 12-19-2012, 10:12 PM   #6
ProudSixxer26's Avatar
STS turbo they are rear mounted in the exhaust and u can get a twin set up for $ 3000. I think they only need 11 psi and it's pushin the
stock internals but since it's in the rear I don't think it would matter. Heres a link.
http://ststurbo.com/universal_turbo_systems
ProudSixxer26 is offline   Reply With Quote
Old 12-19-2012, 10:17 PM   #7
V6in's Avatar
I heard those sts turbos that mount to the exhaust in the rear have crazy turbo lag
V6in is offline   Reply With Quote
Old 12-19-2012, 11:20 PM   #8
Xaperez100's Avatar
Thanks ill look into it
Old 12-20-2012, 12:04 AM   #9
Tmaturbo kits are the ones I would look for if I had the money and time. Im looking into a procharger
02:00 PM
