03 automatic O/D? - Mustang Evolution
Old 12-21-2012, 05:55 PM   #1
mattthegreat210's Avatar
03 automatic O/D?
What is the purpose of the O/D button on the automatic handle??
mattthegreat210 is offline   Reply With Quote
Old 12-21-2012, 06:06 PM   #2
Eturner's Avatar
It turns your Over Drive on and off!.. With it on you have all four gears!.. With it off just three!..
Lol that's the simplest way to put it!...
Old 12-21-2012, 06:12 PM   #3
Is that y the rpms go so high wen I press it?
Old 12-21-2012, 06:13 PM   #4
Eturner's Avatar
Yes because your cruising around in a lower gear!.. Personally I would leave it on unless your running it at the track!..
Old 12-21-2012, 06:21 PM   #5
Crowned1's Avatar
it's basically your last gear. look at it this way, you want it on when your just cruising driving around town, but when you race turn it off up until you reach "Drive" then you turn it back on so you don't redline
Crowned1 is offline   Reply With Quote
Old 12-21-2012, 07:52 PM   #6
It turns off your final gear basically. Automatics always want to shift at the earliest and most prime points and get to the last gear as quick as possible to maximize mpg, so turning it off is eliminating the last gear making you run on the lower ones.
Old 12-21-2012, 08:44 PM   #7
1slosix's Avatar
you can also use it when you overtake other traffic or pass....
carving corners like a boss
Old 12-21-2012, 08:58 PM   #8
brooksyx's Avatar
I always turn it off when passing or getting on the freeway. With it off you get that 1:1 engine to tranny ratio. Over drive gets you better gas mileage though.
brooksyx is offline   Reply With Quote
Old 12-21-2012, 09:22 PM   #9
Eturner's Avatar
It's an Auto!.. All you have to do is Stomp on it and it downshifts on its own!.. No need to turn to OD off!..
Old 12-21-2012, 09:27 PM   #10
1slosix's Avatar
lol I picked up 2 tenths of a second on average on the 1/8th by turning my OD off...and it really does make passing easier at least in the two auto's i've had
Old 12-21-2012, 09:30 PM   #11
Eturner's Avatar
Once I had my tune turning the OD off actually hurt my times!.. Plus we are talking about simply passing someone on the highway!..
Old 12-21-2012, 09:32 PM   #12
1slosix's Avatar
Well let's just say we are talking about an untuned auto then for OPs thread lol, but good to know. I'll be jmodding the car in the spring since i was gonna flush and fill it anyways. and yes even simply passing turning the OD off has always made a difference in my cars. What car is your auto in? is it a sixxer or GT just curious
Old 12-21-2012, 09:47 PM   #13
Eturner's Avatar
Yes in a untuned car it does make a difference!.. But just for the sake of passing its not needed!.. And is not really the wisest thing to do unless your towing something!.. Check out the owners manual!..
But in answer of your question my car is a '04 GT!..
Old 12-21-2012, 10:38 PM   #14
deadsp0t's Avatar
Smh...
That's unimpressive
Old 12-21-2012, 11:18 PM   #15
1slosix's Avatar
to be honest i don't know on a GT...i had a 5 speed in mine. as for the owners manuals i don't read them lol. I guess i'll keep turning my O/D off when i pass until the day my tranny blows
Old 12-21-2012, 11:20 PM   #16
Eturner's Avatar
Always read the manual!.. Lol.
Old 12-21-2012, 11:20 PM   #17
1slosix's Avatar
i refuse lol
Old 12-21-2012, 11:25 PM   #18
Eturner's Avatar
i refuse lol
And that young one will be your down fall!... Hahahahahahahaha.
Old 12-21-2012, 11:33 PM   #19
deadsp0t's Avatar
Wouldn't worry about that....... It's far more efficient then stomping the pedal is..
That's unimpressive
Old 12-21-2012, 11:34 PM   #20
1slosix's Avatar
and you're how old again lol
Old 12-21-2012, 11:36 PM   #21
1slosix's Avatar
yeah seems to be at least to me...i don't even need to really give it much gas to pass when the buttons off...with it on i have to lay in it to force the car to downshift
Old 12-21-2012, 11:37 PM   #22
deadsp0t's Avatar
Yup..
Also.. Age and exp don't always equate to knowledge or ability.. As a general rule in life..
That's unimpressive
10:43 AM
