LED & Gauge cluster questions - Mustang Evolution
Old 12-25-2012, 06:37 PM   #1
Crowned1's Avatar
first off, happy holidays guys and gals! I got the mustang reverse gauges for christmas, and I'm aware that these change the gauge cluster color, but I'm looking to also change the gear shifter lights as well as the AC lights to match. Has anyone does this? Know where to get the bulbs or leds to change them? Is it worth doing? Thanks! this is also on a 2004 v6.
Crowned1 is offline   Reply With Quote
Old 12-26-2012, 02:12 AM   #2
Xaperez100's Avatar
I know for the cluster you have to peel off the film then you can buy bulbs from superbrightleds.com
Xaperez100 is offline   Reply With Quote
Old 12-26-2012, 10:40 AM   #3
1slosix's Avatar
The HVAC uses 194 bulbs..you still gotta sand the film off for them unless you can get the green film slip out. Id assume.the same is true for the PRND21
carving corners like a boss
Old 12-26-2012, 07:00 PM   #4
Crowned1's Avatar
you can't just slip the gauges over them? i got the reverse glow insert gauges. and they use 194 bulbs got it and you think it's the same for the gear shifter? i just want it all to match
Old 12-26-2012, 09:40 PM   #5
Crowned1's Avatar
do you think these will match? im just going to replace them with leds. found a nice write up on it. http://www.superbrightleds.com/morei...edge-base/199/
Old 12-31-2012, 04:16 PM   #6
96NYCGT's Avatar
Send a message via AIM to 96NYCGT
I have Before and after picture on my wall I add blue LED
96NYCGT is offline   Reply With Quote
Old 01-01-2013, 12:22 PM   #7
Crowned1's Avatar
where did you buy those?
Old 01-01-2013, 01:54 PM   #8
96NYCGT's Avatar
Take a sick day off from work to complete my gauge a complete redo for under $50 needle paint from hipoparts.com $6.50 red, White facing gauge from brotherperformance $5.00 & Paint brush from michael arts & craft $5.50
Old 01-02-2013, 07:52 AM   #9
Crowned1's Avatar
im thinking of just buying leds and replacing the bulbs in the gauge cluster and the hvac
Old 01-03-2013, 08:16 PM   #10
slonison's Avatar
How-To: Gauge Cluster/HVAC/Toggle Switch LED Swap
slonison is offline   Reply With Quote
Old 01-04-2013, 09:11 AM   #11
Crowned1's Avatar
Originally Posted by slonison View Post
you are the greatest person alive.
Old 01-04-2013, 09:24 AM   #12
Crowned1's Avatar
where did you get leds for the shifter?
Old 01-04-2013, 09:45 AM   #13
slonison's Avatar
Same bulb as HVAC controls.
Old 01-04-2013, 10:05 AM   #14
96NYCGT's Avatar
What about the clock color
Old 01-04-2013, 10:39 AM   #15
Crowned1's Avatar
ok thanks!
---------- Post added at 11:39 AM ---------- Previous post was at 11:38 AM ----------
you have a stock radio? lucky...
Old 01-04-2013, 10:41 AM   #16
96NYCGT's Avatar
I pick my car up with an aftermarket one
Old 01-04-2013, 06:42 PM   #17
Crowned1's Avatar
how many leds will i need for gear shifter?
Old 01-04-2013, 08:16 PM   #18
slonison's Avatar
Just 1
---------- Post added at 10:16 PM ---------- Previous post was at 10:16 PM ----------
Pictures of your close, is it the one in the dashboard, above the center console vents.
Old 01-08-2013, 12:42 PM   #19
Mustangdust's Avatar
I did my last night I put a vinyl sticker over the orange where it show what gear your in and then painted the light bulb red for now till I get led bulb
Mustangdust is offline   Reply With Quote
Old 01-08-2013, 02:09 PM   #20
Crowned1's Avatar
did you pull the o/d out? or did it stay intact
Old 01-08-2013, 02:37 PM   #21
Yeah I rippit off by pulling to hard lol so I solder
Old 01-08-2013, 02:42 PM   #22
Crowned1's Avatar
lol that's what I'm nervous about
Old 01-08-2013, 03:01 PM   #23
Idk if all are on there that hard but my had bunch of crap in it like hair and stuff for last owner but just one wire and you can fix it easy so don't be to worried lol
Old 01-08-2013, 03:04 PM   #24
Crowned1's Avatar
hah true. I'm installing the reverse gauge cluster i got from AM then im gonna buy some blue leds to Match the hvac gear shifter etc.
Old 01-10-2013, 03:35 PM   #25
Mustangman92's Avatar
Can you tell me all the LEDs I need to make it look just like the other guys who did his blue? I know 1 for the gear shifter but what about the gauges and hvac unit
Mustangman92 is offline   Reply With Quote
Old 01-10-2013, 05:19 PM   #26
Look at this tells you everything you need and how to do
Old 01-10-2013, 09:55 PM   #27
Toggle Switches: (6) 3mm LEDs (6) 1/4 Watt 470 Ohm Resisters Went to local Radioshack! Like 6 bucks total.
I'm not exactly sure what these are...
Old 01-10-2013, 11:14 PM   #28
Anyone?
Old 01-11-2013, 12:14 AM   #29
Xaperez100's Avatar
Originally Posted by Mustangman92 View Post
Anyone?
The toggle switches?
Old 01-11-2013, 06:53 AM   #30
Crowned1's Avatar
Anyone?
these are your toggle switches. aka the 3 buttons beneath the radio. but you might only have one like most v6s which is the defrost.
Old 01-11-2013, 07:06 AM   #31
Are you asking what 3mm led looks like and the resistor look like or what it is
Old 01-11-2013, 07:29 AM   #32
What they look like my local radio shack people are rather clueless
---------- Post added at 09:29 AM ---------- Previous post was at 09:28 AM ----------
Last time I asked them for something they couldnt find if I walked in an found it in 5 minutes
Old 01-11-2013, 08:29 AM   #33
Ok 3mm LEDs look like this they for your TC window defrost and fog light if you got um
Resisters LEDs
ID:	85210   Click image for larger version
Old 01-11-2013, 09:46 AM   #34
So should I only get 2 of each of those since I only have 1 toggle switch?
Old 01-11-2013, 10:44 AM   #35
Yes just make sure you get the right resister for the color you use
04:03 PM
