12-27-2012, 06:30 PM
#1 | | Registered User
| Popping
Like the title says I have a popping noise that is slow at idle and gets louder and faster as the rpms go up. I've been told its an exhaust leak, how do I go about fixing this problem?
12-27-2012, 10:00 PM
#2 | | Staff
go to an exhaust shop and tell them to find the leak...probably a simple weld issue...worse case senario it's coming from the passenger manifold.
__________________ carving corners like a boss
Eibach Strut Tower Brace - Rear Shock Tower Brace - GT Rear Sway - Goodridge Gstop SS lines - SR Performance Springs - Sensa-trac Shocks - Mac Prochamber - Borla Stinger 2.5" Mandrel Catback - K&N - Torqthrust Wheels wrapped in Kumo's - TB Spacer - HIDs & Other Visual Goodies
12-27-2012, 10:01 PM
#3 | | Registered User
Was going to say sounds like the manifold
__________________  )02 Gt, Founder of WE2G
12-27-2012, 10:10 PM
#4 | | Registered User
Did anyone else think it said pooping?
12-27-2012, 10:15 PM
#5 | | Filibuster
I'd guess a manifold gasket before a crack in the manifold or exhaust. Not bashin you 1slow6 (as in no welding needed)...just usually a gasket leak..manifold gasket is my guess..
12-27-2012, 10:24 PM
#6 | | Staff
| Quote:
Originally Posted by 2300turboford Did anyone else think it said pooping? | yes Quote:
Originally Posted by XXSTEVEO66 I'd guess a manifold gasket before a crack in the manifold or exhaust. Not bashin you 1slow6 (as in no welding needed)...just usually a gasket leak..manifold gasket is my guess.. | actually in a 94-04 v6 the most common exhaust leak is a crack passenger side manifold/header thanks to the a/c drip hose which sits right above it. ask me how i know
12-27-2012, 10:34 PM
#7 | | Filibuster
| Quote: |
Originally Posted by 1slosix
yes
actually in a 94-04 v6 the most common exhaust leak is a crack passenger side manifold/header thanks to the a/c drip hose which sits right above it. ask me how i know  | Right on..i'm by no means a specialist in these year v6's..just my .02 ---------- Post added at 11:34 PM ---------- Previous post was at 11:33 PM ---------- I guess I'm out of my element lol..
12-27-2012, 10:38 PM
#8 | | Staff
lol it happens....i hope it is just a gasket, but if that's the general spot the leak is coming from OP might as well buy some new headers lol. i know that's on my to do list on my current sixxer thanks to my crack
12-27-2012, 10:44 PM
#9 | | Registered User
| Quote:
Originally Posted by 1slosix lol it happens....i hope it is just a gasket, but if that's the general spot the leak is coming from OP might as well buy some new headers lol. i know that's on my to do list on my current sixxer thanks to my crack | I can't afford any headers. I was going to just do whatever the absolute cheapest fix was and when I drive it sounds more like its coming from the drivers side more
12-27-2012, 10:52 PM
#10 | | Registered User
When my 99 v6 manifold cracked the cheapest solution was to buy a new one which is 100 bucks but I didn't know any better the shop recomended patching it and I went along with it, total was 180... Yea I was an idiot lol. Regardless you're going to have to get in there and pull it out
12-27-2012, 10:58 PM
#11 | | Registered User
| Quote:
Originally Posted by Venomouz831 When my 99 v6 manifold cracked the cheapest solution was to buy a new one which is 100 bucks but I didn't know any better the shop recomended patching it and I went along with it, total was 180... Yea I was an idiot lol. Regardless you're going to have to get in there and pull it out | If I went to autozone do you think they would have to part?
12-27-2012, 11:00 PM
#12 | | Registered User
Call and ask them. But first make sure that what'smaking the noise
12-27-2012, 11:08 PM
#13 | | Registered User
| Quote:
yes
actually in a 94-04 v6 the most common exhaust leak is a crack passenger side manifold/header thanks to the a/c drip hose which sits right above it. ask me how i know  | I can vouch for the ac runoff cracking the manifold piping or flange,  no fun
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
12-27-2012, 11:12 PM
#14 | | Staff
yeah i agree on hunting down the leak first...lets hope it's a simple fix
12-28-2012, 10:04 AM
#15 | | Evolution's Finest
| Quote:
Originally Posted by 1slosix yes
actually in a 94-04 v6 the most common exhaust leak is a crack passenger side manifold/header thanks to the a/c drip hose which sits right above it. ask me how i know  | Mine did the same thing. With the 99-04 sixxers it is a very common problem. Got it fixed when I had the cats removed. I believe there is a small drip tray guide thingy you can put on the condensor to keep it from cracking the manifold again. I'll have to poke around and see where the thread was.
Just because something "can" be done, does not mean it should be done....
12-29-2012, 08:20 AM
#16 | | Staff
you can just add in a piece of tube...Skargon did i believe
12-29-2012, 10:37 AM
#17 | | Filibuster
JB weld lol..that's the cheapest fix there is..
