96 head gasket - Mustang Evolution
Old 12-30-2012, 04:33 PM   #1
TM2189's Avatar
96 head gasket
I'm getting a 96 tomorrow, it needs new head gaskets. Other than the gaskets what all do I need to change them?
TM2189 is offline   Reply With Quote
Old 12-30-2012, 05:18 PM   #2
jdavis96gt's Avatar
Region: West Virgina
If u had the extra cash it be perfect time for pi swap.
Old 12-30-2012, 06:11 PM   #3
TM2189's Avatar
I wish I did, main focus is get it running then strip down my 96 gt for parts.
Old 12-30-2012, 07:32 PM   #4
Project Pony's Avatar
You should get new gaskets (duh), new head bolts, and take your heads to a reputable machine shop to have them checked.
[SIGPIC][/SIGPIC]
Old 12-30-2012, 07:45 PM   #5
TM2189's Avatar
Thanks, any special tools I should look into?
This is the first car I've ever started putting money into.
Old 12-30-2012, 07:45 PM   #6
Tyoung68's Avatar
Youll need a intake gasket and valve cover gasket
Old 12-30-2012, 07:50 PM   #7
A quality torque wrench, impact gun makes some of the work a little easier. But mostly a decent set of hand tools will get you by.
You can buy all the gaskets you need in a set I believe
[SIGPIC][/SIGPIC]
Old 12-30-2012, 09:08 PM   #8
Tyoung68's Avatar
Old 12-30-2012, 10:22 PM   #9
TM2189's Avatar
One more question, where can I get head bolts? I did a quick online search and all I could find were head bolts for 4.6 and 5.0. Couldn't find them for 3.8l.
Old 12-30-2012, 11:22 PM   #10
Tyoung68's Avatar
Did you try summit? Or cjpony parts maybe or am
Old 12-30-2012, 11:37 PM   #11
TM2189's Avatar
I tried am, I'll check out summit and cjpony tomorrow, are they any good? I've not heard of them before.
Old 12-31-2012, 03:50 PM   #12
davidcseifert's Avatar
Region: Arkansas
3.8 head bolts from most auto parts stores, I went to autozone, just fel-pro bolts will be fine
blower/new cam soon
Old 12-31-2012, 04:15 PM   #13
TM2189's Avatar
Thanks, I'm guessing they can order what I need if they don't have it.
Old 12-31-2012, 04:21 PM   #14
Region: Arkansas
Yessir, most can get stuff the next day, they also have head gaskets if you don't mind using felpro
blower/new cam soon
Old 12-31-2012, 04:29 PM   #15
TM2189's Avatar
Sounds good, need to fix this soon. I totaled my 96 GT earlier today.
03:58 AM
