New intake manifold - Mustang Evolution
Old 01-02-2013, 10:56 PM   #1
Xaperez100's Avatar
New intake manifold
Does it make any difference when you watch to the ford explorer manifold?
Xaperez100 is offline   Reply With Quote
Old 01-02-2013, 10:58 PM   #2
1slosix's Avatar
those 4.0L intakes have completely different designed runner layouts if i recall
carving corners like a boss
Old 01-02-2013, 11:03 PM   #3
Xaperez100's Avatar
Like that? Does it make better performance?
Old 01-02-2013, 11:09 PM   #4
Venomouz831's Avatar
Looks like a windstar
)02 Gt, Founder of WE2G
Old 01-02-2013, 11:09 PM   #5
1slosix's Avatar
that's a windstar intake from a pre '99 windstar minivan...and yes that's a performance upgrade for us
Old 01-02-2013, 11:26 PM   #6
Xaperez100's Avatar
Oh okay that's crazy-.- a van lol what all would I need to do to put on of those on?
Old 01-02-2013, 11:31 PM   #7
1slosix's Avatar
intake, throttle body adapter, gt throttle body i believe (not sure), gaskets, throttle cable extension arm, egr delete, cai tube, coil pack relocation bracket, and probably a few more things i'm forgetting
Old 01-02-2013, 11:39 PM   #8
Yea that is a windstar intake (literally), on a pre '99 Ford Windstar minivan. Notice in the pic he actually took it from the right fender. We had an '01 so it was a little different engine wise.
Old 01-02-2013, 11:47 PM   #9
Xaperez100's Avatar
Dang that's crazy lol I never thought it would be from a van lol
Old 01-02-2013, 11:50 PM   #10
Good for 20hp
Old 01-03-2013, 12:01 AM   #11
Xaperez100's Avatar
Originally Posted by Venomouz831 View Post
Good for 20hp
True
Old 01-03-2013, 01:18 AM   #12
davidcseifert's Avatar
Region: Arkansas
The graph from 2.5K Rpms is with Windstar intake the other is a factory upper intake
blower/new cam soon
Old 01-03-2013, 01:23 AM   #13
Region: Arkansas
You can use the gt tb on 01-04 model V6's since they have the same throttle cable, the 99&00 have to swap throttle cables to use it, also if you use gt tb you have to do an iac relocation since there is no prevision for it on the throttle body itself
You can keep EGR (if you wanted) have to get the Windstar bracket to lower the EGR valve so it won't hit intake
An easy thing to do is swap the guts from a mustang throttle body into the windstars tb so you can just reuse the same factory location for the iac valve if you have hood clearance, also it allows the tb to be opened from the top instead of the bottom to allow making the operation easier
blower/new cam soon
Old 01-03-2013, 11:17 AM   #14
1slosix's Avatar
good to know...you writing that down op
Old 01-03-2013, 02:19 PM   #15
Xaperez100's Avatar
Originally Posted by davidcseifert View Post
You can use the gt tb on 01-04 model V6's since they have the same throttle cable, the 99&00 have to swap throttle cables to use it, also if you use gt tb you have to do an iac relocation since there is no precision for it on the throttle body itself
Got it:p
Old 01-03-2013, 08:15 PM   #16
slonison's Avatar
Parts:
Serafina - A 2002 V6 Build *PIC HEAVY* - Page 3
Installation:
Serafina - A 2002 V6 Build *PIC HEAVY* - Page 2
slonison is offline   Reply With Quote
07:00 AM
