exhaust options.... help!! - Mustang Evolution
Old 05-28-2008, 07:03 PM   #1
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
First, do LT headers actually lower ground clearance? and will the face straight back at bottom of car?
Second, I am building a custom exhaust from headers back. Where can I find 2.25 mandrel bends and cats online for cheap? no local carriers here
Third, what is gained from H-ing or X-ing the exaust? i am thinking of indepent all the way out.
and it will be S/C ed
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 05-28-2008, 08:28 PM   #2
Re: exhaust options.... help!!
LT headers will lower your ground clearance. Expect to rub them alot.
And yes, they will face pretty much straight back.
I dunno about finding the mandrel bends...
It really doesn't matter, the H will give you a little deeper sound, the true dual will sound good. The x-pipe will sound raspy.
Old 05-28-2008, 09:40 PM   #3
exactly what i needed to know!! thanks
now what are yalls (ya'lls) opinion on seperate true dual no x or h ?
Old 05-28-2008, 09:44 PM   #4
i have stock headers, o/r x, and flows........i like the way it sounds. very deep idle, it surprised me when i first heard it, then it sounds like a v6 when you step on it. it still retains it dept in tone (for the most part) except from about 1800-2300 rpms, i dont care for the sound produced there.
other than that, i like it overall
Kyle is offline   Reply With Quote
Old 05-28-2008, 09:45 PM   #5
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
Why the custom built exhaust when there are good parts out there that will likely have better flow, be lighter weight and known to fit? Not questioning your ability, simply saying that it doesn't seem like it is worth the effort.
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Old 05-28-2008, 09:50 PM   #6
well i am trying this new "thing" on my exhaust and I cannot say yet till i know what "it" does but it requires a custom exhaust. plus itll be a fun and unique project. i just wanted to get down the basics again and understand the exhaust from experts.
Old 05-28-2008, 09:55 PM   #7
05RedDevil's Avatar
I can only hope this "thing" is a turbo.
One thing that has not been said yet is the difference in the midpipe crossover, besides tone, is that the X will continue to have (near) perfectly even flow through the entire rpm range. The H does not get as good crossflow at higher rpm's (about 3500+) because of the 90 degree crossover
Some show. Some go.
Old 05-28-2008, 09:56 PM   #8
if you want, i can get you a price on madrel bends, let me know exactly what bends you need. use a x or h-pipe or its gonna sound poppy, h-pipe gives better sound just by equilizing the flow. while the x pipe is gonna scavenge exhaust better and flow alot better.
i also reccomend going with longtubes,a gt catback and a conversion x pipe. just because it will minimize the number of weld which crates restriction.
SimplyOrange is offline   Reply With Quote
Old 05-28-2008, 10:00 PM   #9
You have flows? You mean they have found their way out of the trunk? Or do you mean the sound of them banging around as you stop/go/and turn?
That's cause they are chokemasters.
Old 05-28-2008, 10:03 PM   #10
:yup: i can stop, go, and make turns now without hearing any clunks, clanks, or rattles.
Old 05-28-2008, 10:05 PM   #11
Nice, now if only you could turn on your fog lights...you'd be untouchable.
Old 05-28-2008, 10:08 PM   #12
the new front will have fogs on it.........so i am gonna hold off b/c i dont know if i need gt or cobra fogs
Old 05-28-2008, 10:12 PM   #13
what do you mean when you say "poppy"?
Old 05-28-2008, 10:19 PM   #14
Like balloons popping when you are cruising/slowing down.
vrrrrrrrrrrrm....pop.pop pop pop pop.....
No cool gurgle...just pop pop pop pop pop pop pop pop pop
Kyle had a true dual with no cross over a while back and it sounded bad....not to mention it doesn't let you equalize the pressure between the two sides...so it doesn't scavenge as well as it should. You need some sort of cross over to make it right.
Old 05-28-2008, 10:37 PM   #15
what is scavenge?
Old 05-28-2008, 10:42 PM   #16
from scavenge - definition of scavenge by the Free Online Dictionary, Thesaurus and Encyclopedia.
scav·enge (skvnj)
v. scav·enged, scav·eng·ing, scav·eng·es
v.tr.
1. To search through for salvageable material: scavenged the garbage cans for food scraps.
2. To collect and remove refuse from: The streets are periodically scavenged.
3. To collect (salvageable material) by searching.
4.
a. To expel (exhaust gases) from a cylinder of an internal-combustion engine.
b. To expel exhaust gases from (such a cylinder).
5. Metallurgy To clean (molten metal) by chemically removing impurities.
v.intr.
1. To search through refuse for useful material.
2. To feed on dead or decaying matter.
Old 05-28-2008, 10:44 PM   #17
My understanding of it is *deep breath*...it brings the exhaust together to increase flow velocity instead of just having the exhaust being all turbulent and flowing all over bouncing around inside the pipes....smooth flow is faster flow which creates less back pressure which lets the motor breath better and get the exhaust out of the motor faster so the air come in faster and more fresh air comes in because more exhaust can get in the duration of the stroke and more air means more power.
So yeah, basically, it makes the exhaust flow more smoothly so the motor can breathe better and make more power. It increases the efficiency of the motor.
Old 05-28-2008, 10:47 PM   #18
how big does the cross pipe for the H have to be?
Old 05-28-2008, 10:49 PM   #19
THe same size as your flow tubes as far as width goes and just long enough to not be an X pipe. There really is no set length it has to be to be considered an H....just enough of a crossover tube so you can say it isn't an X pipe.
Old 05-28-2008, 10:56 PM   #20
id like to keep low end torque..... so i was going to go for 2.25. woukld you agree
Old 05-28-2008, 10:58 PM   #21
i have 2.5 and didnt notice any loss
Old 05-29-2008, 01:57 AM   #22
But 2.25 will sound much better on the 6 instead of the 2.5 which sounds empty and hollow at times due to lack of air movement.
Old 05-29-2008, 07:46 AM   #23
scavenging with an x pipe actually creates a vaccume on the headers because it uses the exhuast flow from one side to push the exhaust crossing it out of the back, since all of the air is in a way"connected, it results in better flow than an h pipe which puts a little backpressure on the header.depending on your application, you may want the backpressure because it retains low end torque on a natrally aspirated engine especially a v-6.on boost applictaions, the x pipe is the way to go.
as far as the crossover tube, they can be different sizes to change the tone, the bigger the crossover pipe, the deeper the tone which is why a mac prochamber is so deep sounding, mmff did a write up on this about 1 1/2-2 years ago try searching for it.6" on the length of the crossover is a happy medium.
rob is right, stick with a smaller size(2.25) into the mufflers, and run 2.5 tips so it doesent magnify the lack of cubic inch.also runing a 2" crossover pipe will help it keep the backpressure and sound like it has more cubic inch.
we stock a muffler that sounds just like a gt when ran through 2.25 pipes and a h-pipe, kyle has heard it through an x-pipe and 2.5" piping and i think he liked it.they are the same ones im running on my cobra motor, kyle is gonna cream when he hears it today.
poppy: dabababadadada-pow-pow-dadabadabadaba
Old 05-29-2008, 09:54 PM   #24
DAMN.. my experiment requires seperate dual... I am gonna have to skull on this one for a while.
Old 05-31-2008, 02:36 PM   #25
Send a message via AIM to VCS_SSSTANG
You don't need a Mid pipe at all...
And flow original 40s = best sounding muffler on a V6.
VCS_SSSTANG is offline   Reply With Quote
exhaust
« HP | Mods Question! »
options on a new gt Cdbformula General Mustang Discussion 0 09-27-2009 07:14 PM
Blower options.. MonteCitan 1979-1995 Mustang GT 9 01-24-2009 09:24 AM
Exhaust options wvstang5.0ho 1979-1995 Mustang GT 18 07-13-2008 11:48 PM
Possibilities with my options Matt'sredbeauty Mustang Wheels & Tires 13 03-11-2006 11:36 PM
Ok, looking for 3" exhaust options PureVenom The Bar 9 01-27-2006 05:48 PM
04:35 PM
