1997 Mustang Almost Stalling? - Mustang Evolution
Old 08-20-2009, 03:30 PM   #1
i have a 97 v6 stang and it idles fine and accelarates fine but when i am slowing down and its going to downshift (auto trans) the rpm will go right down and it will shake a little bit almost stalling out but then the rpm comes back up to normal?? why is it doing this and how much to fix it>?
howahkan is offline   Reply With Quote
Old 08-20-2009, 03:54 PM   #2
It's weird that it idles fine but yet almost stalls when slowing. Does the problem go away when your engine heats up? This problem could be due to many reasons;
-Incorrect idle speed
-Fuel filter clogged and/or water impurities in the fuel system
-Damaged or wet distributor cap and wires
-Emissions system components faulty
-Faulty or incorrectly gapped spark plugs/wires
-Vacuum leak at the intake or hoses
-Fuel injection or engine control systems malfunction
As for a price, it would depend on the problem. Best thing to do if you're worried about cost and aren't sure what the problem is, is to take your car into a shop and get an estimate of repair. They can diagnose the problem for you and depending on what the problem is you may be able to fix it yourself. Or, make friends with a mechanic
akira4 is offline   Reply With Quote
1997 mustang
03:57 PM
