Mods Question! - Mustang Evolution
Old 05-29-2008, 11:44 PM   #1
SerbStang's Avatar
Mods Question!
Ok you can see what I have right now in my sig! What else can I do, that would not have to be removed later when I put the s/c...how about some pullies? Also I have a 255lb fuel pump, and new injectors (black with green top, idk what size are they, got them with the s/c kit)..now can I put the pump and injectors even though the s/c is not installed yet, and later just stick with them when installing the s/c?
SerbStang is offline   Reply With Quote
Old 05-29-2008, 11:52 PM   #2
SerbStang's Avatar
Re: Mods Question!
Well I guess I didn't know how to add a signature, but anyways here is the mod list:
Mods: MAC LTs, o/r H pipe, flowmaster 40s, cai,
Motive 4.10, FRPP t loc, NGK Tr55, msd8.5mm
Next: Vortech (complete kit waiting), SCT xcal, UDP
- 2001 V6 Auto -
Old 05-30-2008, 12:32 AM   #3
Re: Mods Question!
I would wait. Why tear down twice? You'll be under the hood once for the kit so do it all one one day- or two of you hit a glitch.
Women prefer good handling to quick rides!
gdcpony is offline   Reply With Quote
Old 05-30-2008, 02:14 AM   #4
SerbStang's Avatar
Re: Mods Question!
Yea thats what I thought! But how about the UDP, it's not like its some big mod (comparing to fuel system)...could I at least go with it before s/c?
And I also got some chip with the vortech kit but I'll wait on that!
- 2001 V6 Auto -
Old 05-30-2008, 12:15 PM   #5
Re: Mods Question!
How is your S/C driven? Did the pulleys come with it? You'll need to use the kits crank pulley at least. Unless they use an add on pulley to drive the S/C. Also the CAI will be gone too. (I need one of those if you plan to sell it cheap). Your S/C kit should have included two or even three pulleys with it; the one on the compressor, a new crank, and often a tensioner too. It should also have any chip/ tuning needed to master the extra fuel and air you'll be pushing in. Unless it is self oiling it should have two oil line too a feed and a drain. Then the ducting to replace your CAI to the compressor and then to the intake- if not inter-cooled. And of course any brackets and misc parts too. this is assuming it is a centrifugal style (Vortech) and not a roots/twin screw (Eaton). They are a different ball game, but great for low end.
Can't wait to hear how it runs, but be a bit patient and try not to buy parts you'll need to take off later. (Of course, I need UDP's too and used is cheaper..... mmm.... go ahead add them! LOL)
Old 05-30-2008, 12:30 PM   #6
SerbStang's Avatar
Re: Mods Question!
Well Im sure I saw at least one pulley...the kit is at my gf's so I can't take a look of it, but here are some pics!
- 2001 V6 Auto -
Old 05-31-2008, 12:32 AM   #7
Re: Mods Question!
I just looked up the kit and it does ride the drive belt. So yes, UDP's SHOULD work. You would need a different belt than the kit's or your current one. Find some string once the kit is on and wrap it around the pulleys once you have the kit on. Have a friend hold the tensioner in position and take that length for a start on your belt. It will be really close. Watch for slipping as that will cut your boost.
Old 05-31-2008, 12:55 AM   #8
SerbStang's Avatar
Re: Mods Question!
And how about cams...Im not too familiar with those! Is this cams: http://www.supersixmotorsports.com/p...atrev3Cams.pdf
Do they give any HPs?
- 2001 V6 Auto -
Old 05-31-2008, 01:52 AM   #9
Re: Mods Question!
Yep those are cams. As far as which is best for you it would be best to contact the maker and tell them your plans. An HCI (Heads/ Cam/ Intake) kit might be right up your alley if you have the cash. With forced induction it could really wake up your car. On a non forced motor I have heard as much as 50-80 HP from them. Depends on your plans and budget. I don't have the budget for any of this anymore (family man now), but I ran a 4.2 with nothing more than gasket matched and polished heads and intake, a truck cam shaft with high ratio rockers, a CAI, Al flywheel and driveshaft, t-loc on stock gears, longtube headers, and a GT take off cat back on my last Mustang. It was extremely fast and would make mince meat out of most anything on a good twisty road. Most of the money in that car, like all mine, went into the suspension.
Old 05-31-2008, 01:56 AM   #10
Re: Mods Question!
Here you go. same seller.
http://www.supersixmotorsports.com/p...3PowerPaks.pdf
Old 05-31-2008, 10:44 AM   #11
SerbStang's Avatar
Re: Mods Question!
Yeah I've seen those power packs too, but they are out of my budget right now...I also have a complete Vortech kit waiting to be installed. I was just curious about the cams, cause they are like 400 (not that bad), and I was just wondering if "only cams" can give some HPs, without the whole power packs?
- 2001 V6 Auto -
Old 05-31-2008, 02:31 PM   #12
Send a message via AIM to VCS_SSSTANG
Re: Mods Question!
Lovely Misinformation: You don't want to use a UDP with a supercharger.
VCS_SSSTANG is offline   Reply With Quote
Old 05-31-2008, 04:27 PM   #13
Re: Mods Question!
I said "could". With a smaller blower pulley he could make the same boost. You are right with a stock blower pulley he would lose boost.
And it would be only one cam. Yes it would help.
mods upton7 1996-2004 Mustang GT 14 04-08-2009 03:13 PM
What mods? 00 V6 smith710 Pre-2005 V6 Mustang 15 05-01-2008 12:03 PM
all mods are done...........almost Kyle Pictures and Videos 26 04-24-2007 03:52 PM
what mods...... ChickStang02 1996-2004 Mustang GT 22 04-23-2007 04:22 PM
Excited about my upcoming mods! + Lock Lugnut question mexor The Bar 9 08-18-2003 08:23 PM
02:37 PM
