SCT or Diablosport - Mustang Evolution
Old 06-02-2008, 08:42 PM   #1
SCT or Diablosport
Okay, i'm going to break down get a tuner for my 03 auto. I want to firm up shifts, reset the speedo for gears and tlock, and increase throttle response to hopefully gain better acceleration and a few more ponies.
First, am i on the right track with the tuner, will it free up hp and torque?
If so, which tuner is going to do this better? The diablosport predator or the sct xcalibrator 3.
Any input from either tuner owner would be great
Thanks
Old 06-02-2008, 08:49 PM   #2
Re: SCT or Diablosport
sct
Kyle is offline   Reply With Quote
Old 06-02-2008, 08:50 PM   #3
SCT...and in 5..4...3...2...1....rwboring will be in here to say why not sniper.
Anyhow..SCT...they both tune just fine, however the datalogging abilities of the SCT are far superior.
Old 06-02-2008, 08:54 PM   #4
So will SCT give me more power and better acceleration than stock?
Also do the preloaded tunes require premium or better fuel?
Old 06-02-2008, 08:55 PM   #5
Also, I want to add...while the SCT is the one I prefer, if you have a tuner local to you, you should choose whatever they use...that was my initial reason for going SCT...local guy was SCT only. Now, I'm glad I went because of the data logging abilities over what the predator offered me.
Old 06-02-2008, 08:57 PM   #6
Don't waste your time with pre-loaded tunes. See my comments in the 02 sensor thread by lowering....
IF you go SCT, go with one from Justing at VMP Tuning. You can get the SCT with 3 custom tunes for your car for basically the same price...or damn near the same price...as a base SCT tuner.
Yes, all tuners will give you more power...and if you go with VMP, you can get one for 87, 89, and 93 octane so you can choose what to run in your car today.
Old 06-02-2008, 08:58 PM   #7
or you go big with a 93 safe, 93 aggressive, and 93 race tune
**** that 87 bull****
Old 06-02-2008, 09:01 PM   #8
I like your thinking kyle, but unfortunately mine is a daily driver
Old 06-02-2008, 09:04 PM   #9
so is mine..........my 04 has 95k miles on it. i've been running it like that since about 30k miles. it has not shown ONE sign of weakness.........except for a pinion leak, which is taken care of in about a month or so, hopefully.
the car runs just as strong as when i first got it tuned........meticulous maintenance is the key
*knocks on wood*
Old 06-02-2008, 09:18 PM   #10
That too...but I got the impression saving 30 cents a gallon might be on his mind....if I Could run 87 I would be during the week, and then run the good stuff on weekends.
Old 06-02-2008, 09:22 PM   #11
I just checked out VMPs tuners. It looks like the SCTs come either preloaded or ready for custom tunes. I'll have to call and talk to Justin, maybe I'm just an idiot, the whole tuner situation is confusing to me. I just want the gains to be worth the 400 dollars spent. I do appreciate all your guys input
Old 06-02-2008, 09:24 PM   #12
The shift point changes alone will be worth it.
Justin is also a member on here...justin00stang I believe is his user id. You can PM him on here.
And you will get the most bang for your buck by getting a custom tune from him over the pre-loaded "one size fits all" tunes that come on the tuner.
Old 06-02-2008, 09:25 PM   #13
Yah, maybe two 87 tunes, one for mileage, and one for performance, and a third tune for a higher octane.
Old 06-02-2008, 09:27 PM   #14
You're better off with an 87 tune for mileage then a 93 street tune and then an aggressive 93 tune for the track. I mean, who is going to run 87 and try to get performance out of it? It won't be worth it really.
But, that's all stuff you can talk to Justin about.
Old 06-02-2008, 09:33 PM   #15
My only question is would the tuner be more effective after more engine/performance mods. Right now i only have exhaust and 245s and 315s if you can even call wheels/tires mods.
I will probably do more mods this summer, and could wait and get the tuner closer to the fall to make it more effective. I could also save on getting a new tune after more mods.
Old 06-02-2008, 09:56 PM   #16
i would do at least an intake either before or at the same time you get the tuner, maybe even an udp too
Old 06-02-2008, 10:39 PM   #17
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Agree with Kyle, try to get the UDP/CAI/Exhaust all done, then slap on your tune. Gives your tuner few more extra variables to run along with. The better the tune, the better the performance gains.
Cajun JungleBoy is offline   Reply With Quote
Old 06-03-2008, 05:13 AM   #18
ChrissyStang02's Avatar
Region: Iowa
Send a message via MSN to ChrissyStang02 Send a message via Yahoo to ChrissyStang02
I'm definitely going SCT.
What's the difference between the safe aggressive and race tunes? Just the way it makes the car run? I would pay prem. for the GT if it makes it's worth it with the tune.
My baby...
No, it's not my boyfriend's car and no, you can not drive it.
2002 Mineral Gray Mustang GT ~Dominic~
MagnaFlow Catback Exhaust, CAI, Mach 1 Grille Delete and much more to come. ***Sold. New 5.0 GT coming soon!!!
ChrissyStang02 is offline   Reply With Quote
Old 06-03-2008, 07:25 AM   #19
Herbstang's Avatar
LMAFO !!!!! SCT is the way to go all tunes from VMP Tuning - Buy Ford SCT & GM Custom Handheld Flash Tuners Performance Economy Towing are dyno proven Support the site sponsors
Old 06-03-2008, 08:28 AM   #20
The aggressive, in my case, is my track tune with adaptive learning. my track tune also has adaptive learning turned off so the computer won't try to figure out what it needs to do based on my driving habits. It basically makes it do what it is commanded instead of trying to learn at all....that way you can run on that razor's edge the whole time the tune is installed.
My safe tune is 2 degrees of timing less so that if I get some **** gas I don't start detonating. It's about 15-20 hp less than my agressive tune.
Old 06-03-2008, 08:32 AM   #21
Send a message via AIM to rwboring
haha i didnt see this till now... ehh i think i might be done... that way if i ever make a trip down south i can spank all you SCTers :duckhunt: i cant give out ALL my secrets
rwboring is offline   Reply With Quote
Old 06-03-2008, 08:36 AM   #22
Herbstang's Avatar
It scares me to death. But I gotta agree with Mikey !!!! my 3.9 got 188RWHP 215RWTQ on the dyno Also have a intake spacer
Old 06-03-2008, 08:37 AM   #23
Mikey has wisdom with the turning of 21 yrs of age... no more retardedness ;P
Old 06-03-2008, 08:39 AM   #24
Just let me know if you want me to run street tires or drag radials and whether you want me to run my safe tune or track tune.
Old 06-03-2008, 08:52 AM   #25
let me know too, if you want me to take the bottle out , or 1/2 the coils off.lol
SimplyOrange is offline   Reply With Quote
Old 06-03-2008, 10:10 AM   #26
im talking about GT's as in without cobra motors ... (please see other thread in V6 section where i said i dont compare GT's to cobras OR v6's to GTs)... i wouldn't be afraid to line up against a similar modded GT...
Old 06-03-2008, 10:33 AM   #27
awwwww... c'mon i dont even have a sniper on it...
Old 06-03-2008, 10:49 AM   #28
no but you have 4 cams! hell id line up... im not afraid to lose... esp if its a mustang... its the GMs i dont like to get walked by!
Old 06-03-2008, 10:55 AM   #29
i dont have 4 cams, by forged i meant like forged signature, its a wanna be cobra motor
whoa, u far away...
Old 06-03-2008, 11:14 AM   #30
04 cobra heads/cams... thats what gets me not the forged... its the 100 extra CFM of flow...
Old 06-03-2008, 11:16 AM   #31
That's not what you said though...you said us SCT guys...I'm an SCT guy.
Old 06-03-2008, 11:16 AM   #32
no those are forged too, like a fake signature.
would have to take a plane to get to the race .
Old 06-03-2008, 12:34 PM   #33
haha you guys are killin me!!!
Old 06-03-2008, 01:29 PM   #34
Herbstang's Avatar
:pop2:
Old 06-03-2008, 01:31 PM   #35
sct or diablosport 3.8boii Pre-2005 V6 Mustang 50 04-12-2010 05:54 AM
SCT chip or SCT Programmer? ninty6stang 1996-2004 Mustang GT 7 07-02-2008 11:57 AM
Selling My Diablosport Predator. steedav6builder Mustang Parts for Sale and Wanted 28 02-12-2005 11:21 AM
Diablosport Predator steedav6builder Pre-2005 V6 Mustang 24 10-11-2004 07:52 PM
sct vs diablosport which one? gforces69 Pre-2005 V6 Mustang 15 10-01-2004 11:01 AM
10:24 AM
