How would u burnout in a 2003 ford mustang V6 that is automatic? - Mustang Evolution
Old 03-08-2010, 12:45 PM   #1
clamp off the rear brakes..
Rhys is offline   Reply With Quote
Old 03-08-2010, 12:50 PM   #2
for one thing stay away from doing the neutral slams-good way to blow a u-joint or worse. if you are so stubborn that you need to do this-go to a nice big parking lot(when the cars and cops are gone) and wet the tires down,crank the wheel and let her loose.be careful because once they let loose-you can lose control real easy.TIRES AND TICKETS ARE NOT CHEAP-HAVE FUN
raedford is offline   Reply With Quote
Old 03-08-2010, 01:29 PM   #3
Unless you had a limited slip unit put in your axle don't do it, one-wheel burnouts are just embarrassing.
Burnouts with automatics are easy, just brake torque it.
natal is offline   Reply With Quote
Old 03-08-2010, 01:56 PM   #4
power brake it or spray the tires with wd40 wet the ground in front of the tires then power brake it that way
dagoberto is offline   Reply With Quote
Old 03-08-2010, 02:22 PM   #5
roll on to some slick cement and hose it down then turn the wheel all the way to the right and punch it
lucan is offline   Reply With Quote
Old 03-08-2010, 02:41 PM   #6
Neutral slams!
imported_art is offline   Reply With Quote
08:39 AM
