Engine dies during (clutch in) braking - Mustang Evolution
Old 06-06-2008, 11:16 PM   #1
ve been trying to figure out why my engine has been acting up lately. First off I have a H/C/I SSM Stage 2+ setup with Procharger P1SC @ 11psi dyno tuned with mafia extender. Ever since the warm weather came (Houston) it seems like I can hear even more noises from the engine area. When I clutch in at RPM's anywhere above 2k it has this chatter noise... don't know and don't believe it's from the spec stage 3 clutch at all since it's way out of break in. I also notice kind of a chatter or gobbling type noise coming from the procharger side of the engine bay during highway rpm's (3.73's) at 2.3K+ which didn't used to sound like that.
Other things I've noticed is that when it's windy and a gush of wind blows on my car, some times my car all of a sudden gets all jerky. I don't know why.
The biggest problem is that during stop and go traffic or when I have to moderately brake either hard or fast... when I push the clutch in, the rpm's drop real fast and sometimes it drops below 500 rpm to the brink of either wanting to die or dies period.. espcially during those left turns. I've found that if I don't clutch in, I really don't have a problem.
I've already replaced the previous IAC valve which correcting a large sum of my problems last time this started happening.. largely because idling was very bad. But now idling is no problem.
I'm pretty confident I've got 0 vacuum leaks, but I'll have it checked tomorrow by a different set of eyes as well as the brake booster. I'm also going to get a new set of TR6's and some wires too.
Is there any suggestions or possible explanations why I might be experiencing this?
_________________
machoman013 is offline   Reply With Quote
Old 06-07-2008, 12:56 PM   #2
Re: Engine dies during (clutch in) braking
your maf could be going, that could be causing the dying, did you try to readjust your clutch pedal
jedwards242000 is offline   Reply With Quote
Old 06-09-2008, 10:51 PM   #3
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Sounds like a MAF issue to me too. The wind thing might be caused by gusting air getting pushed through the air filter (a common complaint on 5.0 mustangs with CAI) if you have a fender mounted air filter. If the MAF is dirty or failing it probably can't keep up with the changes in air density and is sending false signals to the PCM
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-09-2008, 10:54 PM   #4
To be honest this is part of having a centrifugal blower on a car...the air currents are hitting back at the maf with the sudden closing of the throttle body. They can adjust for it in the tune but it will relearn it again.
In other words, don't clutch in, leave it in gear to nearly a stop and you'll solve the problem.
Old 06-10-2008, 06:42 AM   #5
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Hmm, I have no problems like that on my 5.0 with the vortech....
Cajun JungleBoy is offline   Reply With Quote
Old 06-10-2008, 07:40 AM   #6
spec clutches are known to chatter not just during break in, if it goes away when you let the clutch out then it sounds like a throw out bearing.
Old 06-10-2008, 02:34 PM   #7
Hrm interesting answers. But I also hear the same noise when I'm not clutching in too when I just let off the gas during highway rpm's or accelerate to highway rpm's. It's like my P1SC decided to get louder when summer came. I got my sparks changed. I didn't know we had to change them at 10k and the fuel filter at 10k (doing next week). Some new observations, the engine wants to die less. Another shop owner also recommend I change the fuel filter more frequently.
Old 06-29-2008, 04:59 PM   #8
check the brake booster
fjh321321 is offline   Reply With Quote
Old 06-30-2008, 08:33 PM   #9
I have the same problem on my stock 3.9. It hasnt done it in a while. Probably 4 months. But during the winter it did it 3 or 4 times within a few weeks. Then I got it checked out and the dealership couldn't find anything wrong. Then its done it once since then. And yeah I've noticed it only after rapid acceleration then pushing the clutch quickly or on the highway and slowing down and pushing in the clutch around the higher speed interchanges.
Dark04ShadowV6 is offline   Reply With Quote
Braking wiarumas General Car Discussion 10 07-02-2008 12:48 PM
weak braking greenpony02 Pre-2005 V6 Mustang 9 08-08-2005 06:04 PM
questions about braking charkelly9 Pre-2005 V6 Mustang 2 03-28-2005 01:12 PM
braking tech oaktonarcher Pre-2005 V6 Mustang 11 02-25-2005 02:46 PM
Braking issues fastmustangs1 Pre-2005 V6 Mustang 3 10-10-2004 09:54 PM
02:24 PM
