Help Replacing Mirror - Mustang Evolution
Old 06-08-2008, 09:09 PM   #1
I have a 2005 Mustang, V-6 model. I knocked my passenger mirror off and have two questions:
1. Who is the reliable internet parts dealer to order the new mirror from?
2. It looks like it attaches with three screws which go thru the door from the inside by the window. However, this is covered by a trim piece inside which may or may not be attached to the door panel. How do I remove this interior piece to reach the screws in order to attach the mirror?
Thanks for any help!!
Writesfast@aol.com
Buck is offline   Reply With Quote
Old 06-09-2008, 10:47 PM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: Help Replacing Mirror
You need to take that trim piece off the inside of the door. I haven't done a mustang mirror yet, but I can tell you that usually you need to take the whole inner door panel off to get that little triangle of plastic loose. There should be a screw behind that door handle on the inside, maybe one more near the door pocket at the bottom. Really most doors are just snap together for the most part.
Does anyone else know the exact locations of the hold down parts for this guy?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-10-2008, 08:16 PM   #3
Horse, thanks, I actually found a website with detailed instructions on removing the door panel, but wasn't sure I needed to do so. From your post, I see that I do! Thanks for the help.
Old 06-10-2008, 10:01 PM   #4
You could try V6 mustang stuff or new takeoff OEM, sometimes they have the 05-08 parts already painted. CJ Pony Parts sells the mirrors also.
Old 06-12-2008, 12:42 PM   #5
On my 2000 I only took off that small piece and replaced the mirror.
Women prefer good handling to quick rides!
gdcpony is offline   Reply With Quote
Old 09-23-2008, 09:36 AM   #6
I have a 2000 ford mustang v6 and my passenger side mirror got knowcked off so its hanging by its wires. I also have the mach speakers. How do i get the speakers off so that i can change my mirror. Any help is appreciated.
BMustang1 is offline   Reply With Quote
Old 09-23-2008, 11:22 AM   #7
Lightbulb Re: Help Replacing Mirror
Maybe a good excuse to upgrade to the Agent 47 Retro Mirrors? . . . .
Vaya con Dios.
4thMustang is offline   Reply With Quote
Mirror replacement BMustang1 Pre-2005 V6 Mustang 5 09-23-2008 06:38 PM
tires like mirror carlosc Mustang Wheels & Tires 22 01-26-2008 02:03 PM
Mirror Bulbs Mustang414 Mustang Audio & Video 1 05-18-2005 09:51 PM
Mirror! red herring Mustang Parts for Sale and Wanted 6 04-14-2005 02:49 PM
replacing a mirror mexor Mustang Audio & Video 14 03-07-2004 07:48 PM
07:11 AM
