I need some advice ... i keep getting code p0300 random misfire? - Mustang Evolution
Old 03-22-2010, 10:15 PM   #1
i just recently swapped out my engine . i have a ford mustang V6 3.8l engine. i found a engine that has only 55,00 miles on it but it was a 1997 and my car is a 1996. i asked around and multiple people told me that they were the exact engine and i shouldn't have a problem with it. once i threw the engine in there it ran find for about 3 weeks. but just recently i got a code p0300 random misfire. what should i do and were should i start?
cruz is offline   Reply With Quote
Old 03-22-2010, 10:29 PM   #2
when you swapped engines did you replace the plugs and wires with new ones? did you go with oem parts or did you go with aftermarket parts? quality of the parts could be the cause... did you change the fuel filter? start with all the simple do at home stuff and work from there... hope this helps and good luck with it
agni is offline   Reply With Quote
07:04 AM
