Cruise Control Sticking - Mustang Evolution
Old 06-09-2008, 02:40 PM   #1
meteorachick's Avatar
i don't know if its operator error (as my foot is still not 100% strong but i can still drive) but i'm finding that when I hit the brakes to get out of the cruise control it sticks like i'm not hitting the brakes hard enough.
anyone else have this problem?
Modified 2004 V6
Old 06-09-2008, 02:42 PM   #2
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: Cruise Control Sticking
it should disengage cruise control even if you blip the brakes
Cajun JungleBoy is offline   Reply With Quote
Old 06-09-2008, 02:59 PM   #3
yeah i've never had a problem with it, i'm gonna have to play with it tomorrow and see whats causing it to stick
Modified 2004 V6
Old 06-09-2008, 03:03 PM   #4
wow, thank goodness michael is here with his awesome knowledge and great insight to fixing the problem. good job captain obvious
anyway......sounds like a bad sensor from the brake petal to the cruise control system. i'd probably bring that in to get it looked at, that or dont set the cruise. that sounds dangerous
Kyle is offline   Reply With Quote
Old 06-09-2008, 03:05 PM   #5
nah it disengages and i don't use it that often but i'm gonna play with it tomorrow and try to fix it, i have new tools that need to be used anyway (and by new i mean i got them about 2 years ago and still haven't used them)
Modified 2004 V6
Old 06-09-2008, 03:06 PM   #6
jimmy_beaner's Avatar
Region: Iowa
yeap, as soon as you touch the brake (or clutch in a manaul) the cruise should disengage.
Old 06-09-2008, 03:08 PM   #7
Originally Posted by Kyle View Post
wow, thank goodness beaner is here with his awesome knowledge and great insight to fixing the problem. good job captain obvious
Old 06-09-2008, 03:26 PM   #8
Region: Iowa
thanks for your input
Old 06-09-2008, 10:49 PM   #9
I think mine is too touchy, if I just brush the clutch it disengages.
Old 06-09-2008, 11:00 PM   #10
Aidan_04's Avatar
that's cause it hates you Brad.
2004 redfire 4.6L GT / 1994 rio red v6 vert / 1990 7UP LX vert
2804
^^^my fave V8 chick ^^^
Old 06-10-2008, 07:42 AM   #11
if you speed up over the cruise limit and slow back down it will kick back in~ not sure if using the brake petal above the limit to slow down if it will try and kick back in.
Old 06-10-2008, 07:44 AM   #12
if you can touch the top of your clutch petal and make it move barly trying then there is to much slack in the petal and it needs to be adjusted. When ever mine unadjusts itself and I have slack the car is 10x harder to shift and the trans is notchy as hell since the clutch isnt going in as far as it should be. Take up the slack in it.
Old 06-10-2008, 07:50 AM   #13
Hey Brandon, I was told that the cable is split at the end, resulting in me having to press extremely hard on the clutch, and weird shifting:
1-2 is very notchy and difficult, 2-3 isn't to bad, 3-4 is smooth as hell, 4-5 is similar to 1-2. reverse... ugh hard.
And this is with an MGW Shifter...
How could I go about fixing that?
Old 06-10-2008, 07:59 AM   #14
Region: Iowa
any use of the brake disengages it... at least on my last two Mustangs.
that sounds like it would be worthy for its own thread On a second thought... GET YOUR *** TO YOUR DYNO APPOINTMENT
Old 06-10-2008, 08:08 AM   #15
yea I didn't mean to hijack the thread, just branching off of what was said
Old 06-10-2008, 08:21 AM   #16
MonteCitan's Avatar
I can't recall... anyone remember if our cruse control shutoff has a sensor in the master cylinder as well? or is it only a switch under the brake pedal arm
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-10-2008, 10:14 AM   #17
if you were local, id could just take a look under your hood :giggity: j/k
anyways, check the cruise control box under the drivers fender and make sure it isnt dirty causing it to hang up, or like kyle said, the switch on the brake pedal can be going out causing it to take more effort to turn off.
*whispering* psst kyle, there is an off button on the steering wheel too, its not really too dangerous
SimplyOrange is offline   Reply With Quote
Old 06-10-2008, 01:32 PM   #18
the clutch cable generally wont cause the petal to be hard to press, its probably something wrong with the clutch itself.
Old 06-10-2008, 01:44 PM   #19
my clutch was fine, i used it for 30k miles after i changed the cable. i went through 3 steeda cables brfore going oem. i only changed the clutch because i went 6 speed. dont get me wrong i think he has a spec stage 3 or something equivalent but it doesent have that midpoint wher its hard then it suddenly gets soft which tells me it could just be an adjustment
Old 06-19-2008, 05:39 PM   #20
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Anyone know how to get underneath the steering wheel and know what to look for to engage an nonfunctioning cruise control.
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Cruise control upton7 General Car Discussion 12 05-01-2010 05:52 PM
cruise control and door switchs bzgt 1996-2004 Mustang GT 1 03-10-2008 09:43 AM
Cruise Control Out! Debras96stang Pre-2005 V6 Mustang 6 04-28-2006 12:52 PM
tv cable or cruise control ??? fastang11 Pre-2005 V6 Mustang 4 12-25-2005 01:30 PM
1995 3.8 cruise control? v6Stangin95 Pre-2005 V6 Mustang 7 09-24-2005 03:02 AM
01:01 PM
