power adder? - Mustang Evolution
Old 06-11-2008, 08:56 PM   #1
power adder?
alright so im debating on whether or not to supercharge. i have an 02 auto v6. my current mods are 4.10 gears and a posi-trac differential on the 7.5 rear end, bbk shorty headers, flowmaster dual exhaust, k&n drop-in filter, and an sct livewire. im getting an off-road x-pipe soon as well as a cam, heads, and ported intakes. i also have a 65mm halfshafted throttle body waiting to be installed. im hoping for around 220rwhp with all of these. now, i would like to get about 340-350 rwhp. so what would it take? im thinking about doing a vortech with about 11psi. would that be enough? and this is a street car so i want to keep my tranny stock(except for a stall, cooler, and shift kit) and the 7.5 rear. does this sound alright? ill be babying the car for the most part.
tigerfan2771 is offline   Reply With Quote
Old 06-11-2008, 09:07 PM   #2
Re: power adder?
I thought you were the one whose dad wouldn't let do anything to the car...
Old 06-11-2008, 10:51 PM   #3
Re: power adder?
If a certain other V6 owner doesn't go through with his plans, I know of a great idea for you to get to that number.
If he does, then I Would go with a centri style like the vortech. You'll just want to make sure your forge the internals or you'll be picking rod pieces out of your oil pan later. I don't see why you couldn't get to the 300ish mark with a centri with decent boost.
Now, the main question I have is....if you are going to be babying it for the most part, then why spend the money on the blower? That will be a lot of bank just to say you have a certain dyno number and the bolt on....
And yes, Back Yard Customs does do blower installs....rotating assemblies I'm not sure of right this second, but we will be expanding there soon once I find me a nice priced 351 or 460 block.
Old 06-12-2008, 06:48 AM   #4
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: power adder?
...Now, the main question I have is....if you are going to be babying it for the most part, then why spend the money on the blower? That will be a lot of bank just to say you have a certain dyno number and the bolt on....
I wonder who that sounds like.........
Cajun JungleBoy is offline   Reply With Quote
Old 06-12-2008, 03:11 PM   #5
Re: power adder?
ill only be babying it until i get an 8.8 rear, beef up the tranny a bit, and possibly forged internals although i think ill be safe with 9-11psi. once i bump it up, ill do a 4.3 stroker.
Old 06-12-2008, 03:12 PM   #6
Re: power adder?
MMMMM SUPER COUPE!!!!!
Old 06-13-2008, 07:43 AM   #7
Re: power adder?
I wouldnt push it much past 350 as thats about the limit on the stock block... I might even hold it around 300 to be safe. Now if you built the bottom end as well as the top end when you do the heads/cam/intakes then you can push it much farther.
You can always build the motor and get it ready for a blower and then do a single turbo and have an amazing setup. If you are set on a supercharger dont go with a roots blower~ go with a vortech or procharger.
What power adder? allnotch 1996-2004 Mustang GT 8 09-13-2008 08:23 PM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
halfway to power adder tedness Pre-2005 V6 Mustang 10 05-09-2005 03:34 PM
Power adder question ShwoffGT 1996-2004 Mustang GT 4 11-01-2004 03:45 PM
08:08 PM
