Installing an aftermarket deck? - Mustang Evolution
Old 06-14-2008, 12:45 AM   #1
mvp828's Avatar
Send a message via AIM to mvp828
I have a 2000 V6 and am planning to install an aftermarket CD deck within the next week or so.
Here is my question... I have the dual factory decks, and was wondering where (if at all) can I find the trim pieces or a blank compartment to replace the the opening that will be created when I remove the stock CD deck?
Note: I am doing the installing myself, and that is why I need to purchase it for myself instead of paying one of the stores to do it.
mvp828 is offline   Reply With Quote
Old 06-14-2008, 02:29 PM   #2
Re: Installing an aftermarket deck?
You will need the ford removal tools, you can pick these up at walmart or an audio shop for cheap.
As far as the bottom panel, you can probably find a pocket or compartment that will fit this space, shouldn't be too hard.
Install is pretty much straight forward, if you have any questions just ask.
Old 06-14-2008, 03:02 PM   #3
OsirisGuy's Avatar
Metra Part number 88-00-9000 You can pick it up from any car audio shop or Best Buy/Circuit City. Crutchfield and other online install shops should also have it. It's a universal pocket. Just a few screws to attach the bracket and it snaps right in.
The radio will use the DIN cage so you won't need any kit for the radio. I do usually advise to use a radio harness makes things easier to install and a lot cleaner as well. Since you have the separate CD Player I'm assuming that you will need a harness for the Premium System Metra Part Number 70-5511 You'll know if you have the premium system when you pull out the radio the harness will be a long skinny gray rectangular harness and a square black harness. If the two harnesses are the same long skinny gray and black shape you have the regular system and will need this Metra Part Number 70-1770
Expect to pay about $20 for each part.
I'm doing this from memory so I may have some inaccuracies, but should be dead or close on.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 06-14-2008, 08:55 PM   #4
Scut95's Avatar
i had the dual decks in my car too.....when i ordered my new head unit from Crutchfield, they asked if I had the dual....i said yes and they actually sent me a little tray that slides in there and has a trim piece that holds it in.....its very useful actually....in the end i took it out and put some gauges in there, o well
Old 06-15-2008, 02:32 AM   #5
OsirisGuy's Avatar
Since my radio was blue I bought some blue LED lights and stuck 'em in the pocket sides then wired them to my dimmer switch so when I had my lights on they'd go on too and I could dim them as well.
OsirisGuy is right
2002 Mustang GT
Old 06-16-2008, 01:14 PM   #6
mvp828's Avatar
Hey thanks guys... I will have to look into all of that. The LEDs sounds like a cool idea.
I already have the radio removal tools as I had bought them when I did my F-150 Deck.
Need Help Installing New Aftermarket Head Unit and Subs with Amp! 99supercharged Mustang Audio & Video 8 04-15-2010 10:57 PM
dash lights out after installing aftermarket radio vblic 1996-2004 Mustang GT 3 08-10-2007 05:46 PM
Problems with Aftermarket Deck snivz Mustang Audio & Video 3 05-30-2006 05:23 PM
deck? yellowscreamer Mustang Audio & Video 18 05-11-2006 09:22 AM
Looking for head deck Rellik Mustang Audio & Video 1 05-12-2003 06:21 PM
03:08 PM
