Please confirm which gears to put in my mustang - Mustang Evolution
Old 06-15-2008, 08:45 AM   #1
02mach6stang's Avatar
Talking Please confirm which gears to put in my mustang
i have a 02 5 speed 3.8l and others in the forum said to use 3.73 gears on a manual and 4.10 gears on a automatic. Why do people not recommend 4.10 gears on a 5 speed if it adds much more get up and go?
02mach6stang is offline   Reply With Quote
Old 06-15-2008, 12:26 PM   #2
iwannagofast's Avatar
Re: Please confirm which gears to put in my mustang
Eh it dont matter, i got a buddy that has a 5-speed with 4.10s.
The only problem with taller gears is, if you put on a power adder u wont hook on your launch
iwannagofast is offline   Reply With Quote
Old 06-16-2008, 04:58 PM   #3
chris7869's Avatar
How's the wear and tear on the engine rps when cruising the freeway.
Anyone an authority on that one. I here it should be installed w/the t-lok at the same time for v6's so there's no 1 tire fire.
If it's too loud, you're too old.2:
chris7869 is offline   Reply With Quote
Old 06-16-2008, 06:12 PM   #4
yep def needs t-lok for dual posi but i think the 4.10 gears might put out alot more acceleration than the 3.73 gears
Old 06-16-2008, 06:36 PM   #5
1234's Avatar
but then again you will be cruising down the highway at about 4000 rpms, maybe not 4000 rpms but you get what im saying
Old 06-16-2008, 06:47 PM   #6
my mustang with stock gears at 70mph is at about 2800rpms
Old 06-16-2008, 06:50 PM   #7
1234's Avatar
mine is at about 2400rpms at 70mph, if my buddies math is correct. With 4.10s it should put you around 3500 to 3800 rpms at 65 mph there are quite a few factors in that he cant account for, anybody correct me if im wrong
Old 06-16-2008, 07:13 PM   #8
with 4:10s you will be doing 2417rpms at 70mph with 275/45/17 tires(26.74 diameter)
my math is correct...
4.10s are the way to go on a v6, we run 4.10s on a 450rwhp cobra and leave the line just fine.
SimplyOrange is offline   Reply With Quote
Old 06-16-2008, 07:18 PM   #9
1234's Avatar
so with 4.10s you will lose rpms in a stock situation
Old 06-16-2008, 07:33 PM   #10
what is your final gear ratio?, i put in stock gt 5th gear ratio. im using an online calculator.
Old 06-16-2008, 07:35 PM   #11
1234's Avatar
whatever is stock in an 03 gt
Old 06-16-2008, 07:37 PM   #12
Scut95's Avatar
3.27's
Old 06-16-2008, 07:38 PM   #13
1234's Avatar
good to know thanks
Old 06-16-2008, 08:08 PM   #14
SimplyOrange when i run my friends 95 GT wit Spray on 3.73 catching traction is a pain, what kind of tires you got?
Old 06-16-2008, 09:38 PM   #15
ok those numbers i gave you were for a t45, may be a little better with the tremec 3650.
im running 315/35/mikey thompson drag radials, they hook fricken awesome but they are pricey and wear out on the street fast, i paid 700 for 2 shipped, mine hooks solid more due to the suspension, i have fulltubular coilover front and solid race rear. all with no urethane bushings.
Old 06-16-2008, 09:52 PM   #16
so basically you will save gas on the freeway at 70mph just not in the city.
Would there be any problems not hooking with 4.10 gears if i instal a t-lok and have a race suspension all the way around
Old 06-16-2008, 10:01 PM   #17
not if the susapension is set up right, i launch at 5K rpm with just a tire chirp hen my nitrous comes in.
, you wont really gain or lose mpg either way
Old 06-17-2008, 07:34 PM   #18
Scut95's Avatar
with 3.73 or 4.10's you'll lose a little bit of mpg on the freeway but you probably will gain some driving in town
Old 06-17-2008, 08:30 PM   #19
chris7869's Avatar
My main concern is about any type of premature wear any where as a result of the gear change.
Old 06-18-2008, 09:20 AM   #20
no premature wear on anything else, we havent found much difference on average for mpg by switching to 4:10s its just more tempting to romp on it so most people lose mpg because of that fact.
Old 06-18-2008, 01:02 PM   #21
Y2E0L0L5OGWT's Avatar
"Don't fear the gear!"
4.10's in conjunction with a T-Lok for a V6 is the way to go without a doubt....
Old 06-19-2008, 02:01 PM   #22
chris7869's Avatar
I dont know why I had 3.73 in mind for a V6 stick. I thought 4.10 was for Automatic for smoe reason. NO?
Old 06-19-2008, 02:06 PM   #23
you can run any gear with any transmission,for a v6, i reccommend 4.10 for eith er one.
Old 06-19-2008, 03:38 PM   #24
Send a message via AIM to white95v6
yea 4.10s for sure. i like gear.
The First and Only 9 Sec Production Based V6 Stang!!,First over 500rwhp,First and only over 600rwhp
60ft-1.42,1/8th mile-6.25@111mph,1/4 mile-9.83@136.65mph
Sponsored by:
WWW.DELKPERFORMANCE.COM
white95v6 is offline   Reply With Quote
Old 06-19-2008, 04:21 PM   #25
chris7869's Avatar
Okay so gears and t-lok it is, I hear u gotta buy a few extra things to get that done before I hand it over to my mech for install.
Old 06-20-2008, 12:41 AM   #26
SerbStang's Avatar
You should know 4.10 will limit your max speed! I got it together with t loc and pick up is really good you can feel it, but it limits my max speed! Also you will need a tuner to make your speedometer work fine, because the gears will make a difference from your actual speed and what your speedo shows!
Here is the video from couple of days ago (bad quality tho)
- 2001 V6 Auto -
Mods: MAC LTs, o/r H pipe, flowmaster 40s, cai,
Motive 4.10, FRPP t loc, NGK Tr55, msd8.5mm
SerbStang is offline   Reply With Quote
Old 06-20-2008, 05:14 AM   #27
sonic04edge's Avatar
Send a message via AIM to sonic04edge
Another thing to factor in is. Are you going for drag or road course as your primary performance? Also 4.10's will be better for a 1/8 mile, but 3.73 will be better for 1/4 mile. It really just depends on how you plan to use the car. MPG will be about the same either way.
Looking for a mustang
2001 Ford Explorer 4x4
2003 Ford F150 Lariat Screw
1998 Ford Ranger-The DD
sonic04edge is offline   Reply With Quote
Old 06-20-2008, 07:29 AM   #28
[QUOTE=sonic04edge;459147] Also 4.10's will be better for a 1/8 mile, but 3.73 will be better for 1/4 mile.QUOTE]2:
explain...4:10s are fine for 1/4 mile for pretty much anything under 450rwhp.
hes not gonna run out of gear in the 1/4 with a v6...
Old 06-20-2008, 08:06 AM   #29
you will still be able to run well over 120mph.
Sponsored by:
Old 06-20-2008, 04:33 PM   #30
[QUOTE=SimplyOrangeTPS;459148]
He will start to lose top end after the 1/8th mile. Have you driven a v6 mustang? I use to own an 04 v6 5spd and even with the 3.27's I could tell I was losing power in late 3rd and 4th. I use to have a gt with an auto so I've had both before. I also never said he couldn't run 4.10's for the 1/4. I just think the 3.73 will be a better match. Also if drag isn't his primary focus then 3.73 would be a better all around gear.
Well the mustang has been put on short hold sonic04edge The Bar 18 06-22-2010 09:24 PM
What should i put on my mustang? Craser Mustang Wheels & Tires 14 10-24-2009 01:30 PM
I just put in my 3.73 gears tjzola 1996-2004 Mustang GT 8 04-21-2009 05:36 PM
i want to put turbo on my 04 3.9 mustang! Zebs5408 Pre-2005 V6 Mustang 2 03-09-2009 05:43 PM
How To Put On Mustang Hood Scoop carlosc Pre-2005 V6 Mustang 8 01-17-2009 12:16 PM
09:17 PM
