Power window motor - Mustang Evolution
Old 06-16-2008, 08:50 AM   #1
Foxone's Avatar
Power window motor
I got a bad window motor on my 2004 v6, this is the first one of these ive had break, how difficult is it to replace, not much room in there.
Foxone is offline   Reply With Quote
Old 06-16-2008, 10:23 AM   #2
Re: Power window motor
What's it doing? If it just won't roll up sometimes get used to slamming the door, it'll work just fine.
Old 06-16-2008, 02:33 PM   #3
Foxone's Avatar
Wont go down, does not budge, just clicks inside the door, I ran 12 volts straight to the motor, nothing.
Old 06-29-2008, 08:48 PM   #4
try replacing the voltage regulator, had the same problem in my 94 mustang..for my back & front left side windows..
DG_Aviles32 is offline   Reply With Quote
Old 06-30-2008, 07:00 PM   #5
Scut95's Avatar
Usually the regulator and the motor come as an assembly....its not difficult to replace. take the door panel off, disconnect any connectors, losen the bolts to the motor/regulator assembly.....support the window( I even take it out) and then pull the motor out....reverse for installation, and make sure you get the window back in the track properly if you take it out.
Old 07-02-2008, 09:31 AM   #6
Foxone's Avatar
I got it fixed, new motor fixed it. the most ridiculous thing ever is having the entire assembly installed with bolts, then they put rivets to hold the glass to the rest of it, stupid as hell, I had to drill it out and replace with bolts, but she works great now.
Old 07-02-2008, 11:56 AM   #7
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
Good deal.
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Old 07-02-2008, 03:27 PM   #8
Foxone's Avatar
Wouldnt you know it, right after I post this, my wife calls and says its broke again! I didnt know it when I ordered it, but when it came, it was a rebuilt one, GRRR, I went ahead and installed it, now here I sit. Lasted 2 weeks. I just bought an OEM motor via Ebay. I guess we will see......
Old 07-02-2008, 09:14 PM   #9
Scut95's Avatar
atleast you know the tricks to it now and it won't take as long to do
Old 07-09-2008, 04:56 PM   #10
Foxone's Avatar
Found something out, it wasnt the motor. There are two brackets that keep the window from going up to far, they were adjusted to long, letting the window get stuck at the end of the regulators travel, kinda binding it up. Adjusted it about a half inch down, now shes good. I guess if the motor binds on anything, a breaker kicks in to keep the motor from burning up.
Old 07-09-2008, 05:43 PM   #11
RyansQuick6's Avatar
It's got built in stops to prevent it from breaking. That's why they occaissionally get stuck in the down position. Mine got stuck once, months ago, and it's never happened again.
RyansQuick6 is offline   Reply With Quote
Old 01-23-2009, 06:44 PM   #12
hi there, i have removed the door panel and the plastic white sheet / cover, but I don't see the motor yet.
Do I need to unscrew the metal inner part of the door as well? Along with removing all the rubber trim and seals ..
If so, will the window fall out?
subtonium is offline   Reply With Quote
Old 01-25-2009, 07:53 PM   #13
jwalthersoccer's Avatar
Hey guys I was wondering is it hard to put in the drivers side rear window on a 1999 convert?
35th Anniversary Laser Red Convertible V6
All I can do is try and live up to my V8 brotherens glory... :burnout:
First mod AM CAI
jwalthersoccer is offline   Reply With Quote
Old 01-26-2009, 10:43 AM   #14
I just ripped out the window motor in my DD grand prix. The hardest part is just getting the door panel off. Other than that its pretty straight forward.
Old 01-26-2009, 08:43 PM   #15
Thx about how much am i lookin to pay for a motor?
First mod AM CAI
Old 01-27-2009, 07:33 AM   #16
you can go to a junkyard, a pull a part or something and yank one. They seem to be pretty good and reliable overall~ shouldn't cost to much. You can get online for pull a parts and get a quote I think.
Old 02-10-2009, 01:56 PM   #17
ok where are these adjustable window brackets? and do the convert rear windows have them?
thenatster513 is offline   Reply With Quote
Rear Passenger power window motor failure drnelsen 1996-2004 Mustang GT 5 06-26-2009 08:08 PM
Passenger side power window motor replacement jaykay 1979-1995 Mustang GT 1 10-18-2008 02:40 PM
Window washer motor Scut95 1979-1995 Mustang GT 0 11-20-2007 08:59 PM
Power Window Motor Pizon Pre-2005 V6 Mustang 8 05-16-2007 10:19 PM
Window Motor Pizon Pre-2005 V6 Mustang 6 05-04-2007 11:35 PM
10:24 PM
