What would be a good upgrade for a 1995 mustang 3.8l v6? - Mustang Evolution
Old 12-18-2011, 08:30 PM   #1
I'm looking to get more hp and more throaty of a sound. Im going to need a new engine soon considering mine has almost 200,000 miles on it.
nels is offline   Reply With Quote
Old 12-18-2011, 08:46 PM   #2
Sell it and buy a camaro... Then you will have something worth something.
westin is offline   Reply With Quote
Old 12-18-2011, 09:26 PM   #3
Kenne Bell doesn't make supercharger kits for a v6. Best upgrades for a v6 is a dual exhaust, like magnaflow or flowmaster. There are kits that can convert your v6 to a dual exhaust. Downgrade is that it won't sound loud enough like a v8 with a similar exhaust.
You can upgrade your gear ratio to a 4.10 or 3.73 depending on whether its automatic or manual. Best company is Moser Engineering. That would make your mustang a little faster, but would reduce the higher speeds with steeper gear ratios.
You can do other upgrades, small stuff like cold air intake, and a custom tune. With a custom tune, that might be another 30 horsepower depending on the tune. Cold air is 8-10 extra horse power. You won't have any increase really big unless you throw on a supercharger. I wouldn't recommend it unless you want to put $$$$ in your v6. A supercharger retails between $3000 and $4000. You would only get maybe an extra 70 horsepower unless you put more $$$$ in your engine first and have it with improved air flow.
waquini is offline   Reply With Quote
Old 12-18-2011, 09:55 PM   #4
Go get a Kenne Bell supercharger if you have the money. These are pricey and get a K&N air filter and Magnaflow exhaust kit and also get a catback system and your car will be not only fast but will also sound bad as$
Iago is offline   Reply With Quote
Old 12-18-2011, 10:46 PM   #5
2 more cylinders, cause there is absolutely no way to make a V6 sound like a V8 w/out it actually being one
Nevada is offline   Reply With Quote
Old 12-18-2011, 11:43 PM   #6
'95 Gelding with 200K.......... The best upgrade would be to get the V8 Mustang you've been lusting for.............
imported_Garth is offline   Reply With Quote
1995 mustang
07:21 AM
