Where is the fuel relay located on a 1999 Ford mustang V-6 stick shift? - Mustang Evolution
Old 12-19-2011, 08:15 AM   #1
Do not hear fule pump coming on checked all fuses in engin compartment all are good the one 20amp mini running the fuel pumps tests good all other test good. Tripped and reset the fule shut off switch in trunk a few times did get gas for a minute but not long enough to start? I have a new fule relay for this car but CAN NOT FIND WHERE IT IS HIDDEN!!! Have looked onder drivers seat, on back wheel well in trunk passenger side under glove compartment under hood every where I can think of please help I even called for dealership no help THANK YOU!
Brone is offline   Reply With Quote
Old 12-19-2011, 09:05 AM   #2
This may blow your mind, but the 1999 Mustang V6 has no fuel pump relay.
The fuel pump is driven by the fuel pump driver module. It operates the fuel pump through pulse widths rather than constant voltage.
beamann is offline   Reply With Quote
11:13 AM
