Is this a good buy? - Mustang Evolution
Old 11-17-2003, 06:43 AM   #1
Send a message via Yahoo to 98GreenStallion
Is this a good buy?
Well, I think I'm going to try and get those Tokico Mach1 shocks/stuts. So I got that decided. I think I want to go with Steeda sport Springs also. I found a good buy on ebay, but I dont know if its good enough... heres the link
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2441953110
Seems like a good deal to me, but can I get them cheaper any where else? Also do I need to get caster/camber plates with them?
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 11-17-2003, 06:48 AM   #2
Danger Dude's Avatar
You can get ford C springs for $ 80 less and have nearly the same springs
Old 11-17-2003, 11:12 PM   #3
tire's Avatar
Send a message via AIM to tire
yeah that's not a great deal. c springs have gotten better reviews and are 100$.
tire is offline   Reply With Quote
Old 11-18-2003, 05:43 AM   #4
Okay, I will look into the C springs....
RDmotorsport
New dyno
Old 11-18-2003, 09:11 AM   #5
Rick0636's Avatar
I am a firm believer in Steeda Springs, as well as some of their other products, I even have Steeda badging on my GT, though its not really a Steeda car, though it does have some parts from them. I had Steeda front springs, but now I am running Eibachs all the way around, Steedas are made by Eibach, to Steeda Specs, but are actually better than Eibachs I hear. My personal dislike for Cs is that I don't like the idea of buying new springs I have to cut to make them do what I want.
Old 11-25-2003, 10:22 PM   #6
Send a message via AIM to 94GTStang
Rick, I'm with you on the Steeda's as well. I run Steeda Sports on my 94GT. Not a single problem with them or concern.
However, I also run FMS C springs on my 01' and I tend to like those equally as well. But for $99 @ stangstore.com, I couldn't go wrong.
Check out my website to see my rides!
www.geocities.com/GTStanger94
94GTStang is offline   Reply With Quote
Old 11-25-2003, 10:28 PM   #7
C springs have there place without cutting you have a lower front stance and enough clearance for the fox bodies with big fat tires. On the other hand having a dead coil allows you to cut the rerar spring for a level stance with no change in spring rate common with people who attempt to cut stock springs and throws the spring rate off considerably.
Old 12-06-2003, 02:38 AM   #8
Ponycarman's Avatar
Y'all are aware that have a nose down rake improves high speed stability?
Without a nose down rake front end lift is more likely with higher speeds.
An excellent example would be a late 60's early 70's GM midsize, like the Chevelle. Put it over 100 and the front end gets real light and real scary. Not to mention a nose down rake, of about 1.5 degrees, improves mileage.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 12-06-2003, 08:30 AM   #9
Mustangs with a even drop have a natural nose down drop. in a stock spring mustang there is no high speed instability. I have taken my stang to near 140mph and I have not felt any instability!!!!
Old 12-09-2003, 06:40 PM   #10
Well, I am going to cut one coil off the rear C springs, but the question in the matter is how??? I dont think a jig saw will do it... at leiste not very well...
RDmotorsport
New dyno
Old 12-10-2003, 12:07 AM   #11
Rick0636's Avatar
Sabre Saw or jig saw, no way, maybe with a sawzall you might be able to.
is this a good buy?? knoykos 1996-2004 Mustang GT 16 04-22-2009 08:16 PM
Good Buy? Hollywood jack General Mustang Discussion 2 06-17-2008 01:24 PM
Feels Good To Buy Random Ish bluemustang The Bar 8 06-01-2007 05:33 PM
will this be a good buy strike1980 Pre-2005 V6 Mustang 4 11-16-2006 06:36 PM
good website to buy parts Klamdogg06 Pre-2005 V6 Mustang 8 02-16-2004 08:11 PM
02:33 PM
