1997 MUSTANG IDLING AT 500 RPM?! help please! 10 points!!!? - Mustang Evolution
Old 12-21-2011, 11:45 AM   #1
i have a 1997 mustang.
it usually idles at 1400 to 1500 rpm, which is normal for my car.
now it is idling at 500 rpm and it give me a hard time starting up,
when i start it, it dings at me, but no lights on the dash come on.
what might be causing this???
macray33 is offline   Reply With Quote
Old 12-21-2011, 11:48 AM   #2
when was the last time u had a tune up?
dirty Fuel filter
Spark plugs and wires #1 u should change them.
Distributer caps and rotors or
it could be ur fuel pump is weak.
also what is responsible for ur idling is ur air idle control valve which is located on the intake where the air enters the intake manifold this could easily need adjusting. try this one first. if not then ur spark plugs.
Good luck!
Teitr is offline   Reply With Quote
Old 12-21-2011, 11:58 AM   #3
First all cars idle at around 800 to 950 so 1500 signals a problem.....If the air idle control valve is sticking for gunk and buildup it will idle bad up or down. I'm assuming its a 3.8 v6 car same go for the 4.6 v8 car it should be cheap to get the AIC valve replaced.
xavier is offline   Reply With Quote
Old 12-21-2011, 12:01 PM   #4
take the idle air control sensor off and clean it and clean out the throttle body with throttle body cleaner. it would,nt hurt to check the air filter either. it could be clogged up and choking it out.
Kermichil is offline   Reply With Quote
Old 12-21-2011, 12:11 PM   #5
Maybe the engine is the problem or something but muscle cars are good but not the best. You should buy a normal car. Belive me, muscle cars have some problems.
curr is offline   Reply With Quote
1997 mustang
08:49 PM
