Why does my wheel make this noise? - Mustang Evolution
Old 12-21-2011, 07:15 PM   #1
i have a 2002 mustang v6 and i notice my wheels make this weird noise only when it moves i changed the break pads i change the metal holders i put on the back of the break pads the anti noise gel and it still makes so much nosie
dunmore is offline   Reply With Quote
Old 12-21-2011, 07:34 PM   #2
what does the noise like? Does it only make this noise when the brakes are applied ?When I get something like this I jack up the car secure it with jack stands and put it in gear and listen to where the sound is coming from. Sometimes removing the tires help too.BUT BE VERY CAREFUL!!!!! Make sure it is supported good.
sevastianos is offline   Reply With Quote
Old 12-21-2011, 08:02 PM   #3
it makes the noise without using the brakes? maybe the backing plate behind the rotor is bent and rubbing on the rotor or it could be a wheel bearing.
Fahroni is offline   Reply With Quote
Old 12-21-2011, 09:02 PM   #4
Can you explain what this "noise" sounds like?
roselyn is offline   Reply With Quote
Old 12-21-2011, 09:24 PM   #5
Bearing in mind we don't know what the noise sound like I guess it's bearing problems.
Lynd is offline   Reply With Quote
08:05 PM
