2001 v6 3.8 engine noise after new belt - Mustang Evolution
Old 01-03-2013, 07:25 AM   #1
truckdriver0's Avatar
I just changed out my belt on my engine, it has tension, but now i have a new engine wineing when i step on the gas, i can let off of the gas and the nosie go's away? Help.... Any ideas........
truckdriver0 is offline   Reply With Quote
Old 01-03-2013, 11:22 AM   #2
1slosix's Avatar
pop your hood...and manually give it throttle at the TB...listen for where the whine is coming from.
carving corners like a boss
Old 01-03-2013, 11:58 AM   #3
Project Pony's Avatar
Yep, narrow down what is making the noise and we may be able to point you in the right direction.
[SIGPIC][/SIGPIC]
Old 01-03-2013, 03:16 PM   #4
It sounds like its in the back side passanger side of the car. Kinda sounds like an exsust leak by the headers? ????????
Old 01-03-2013, 06:51 PM   #5
It s common for the pass side header to crack from the ac drip.
[SIGPIC][/SIGPIC]
Old 01-03-2013, 08:15 PM   #6
could it just be a gasket leak?
---------- Post added at 09:15 PM ---------- Previous post was at 09:14 PM ----------
O yeah, and is it something that needs to be fixed asap? Or can it wait abit?
Old 01-03-2013, 09:03 PM   #7
1slosix's Avatar
it's one of those i'd fix sooner then later kinda things...if you catch it early enough you can have an exhaust shop weld up the crack...if it's too big you'll either have to replace the manifold, or go ahead and buy headers
07:22 PM
