Im stumped - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Old 01-03-2013, 03:32 PM   #1
99VSixer's Avatar
99VSixer is unknown around these parts
Im stumped
So heres the story..
I go to work.. Everything works fine.
Leave work..everything works fine.
About an hour later i go outside to leave and the car wont start. You can hear it trying to turnover but it just wont go. I kno the battery alternator and starter are all good.
Im thinking its the fuel pump but i can hear it and dont wanna risk buying one and doing all that labor only to find out its not the problem.
Any other possible problems?
99VSixer is offline   Reply With Quote
Old 01-03-2013, 04:13 PM   #2
Kingmidas87's Avatar
Kingmidas87 is unknown around these parts
Clogged fuel filter?
Kingmidas87 is offline   Reply With Quote
Old 01-03-2013, 04:22 PM   #3
TaylorF25's Avatar
TaylorF25 is unknown around these parts
Look into checking your coil box too... That damn part has cost me a lot of time in the past.
TaylorF25 is offline   Reply With Quote
Old 01-03-2013, 04:32 PM   #4
99VSixer's Avatar
Fuel filter should (keyword should) be good, coil pack and spark plugs/wires all good
Old 01-03-2013, 04:46 PM   #5
1slosix's Avatar
1slosix is just getting started.
Check fuel pressure
carving corners like a boss
Eibach Strut Tower Brace - Rear Shock Tower Brace - GT Rear Sway - Goodridge Gstop SS lines - SR Performance Springs - Sensa-trac Shocks - Mac Prochamber - Borla Stinger 2.5" Mandrel Catback - K&N - Torqthrust Wheels wrapped in Kumo's - TB Spacer - HIDs & Other Visual Goodies
Old 01-03-2013, 05:45 PM   #6
NewMtang's Avatar
NewMtang is unknown around these parts
Did you fill your tank on that day? If so, maybe water now in your tank.
2013 Silver V6 Premium
Cargo Area Mat, Dash Carpet Cover, Satin JLT Oil Separator, Ford Racing Handling Package, MGP Black Caliper Covers, MMD Bolt On Hood Strut, Airaid CAI, Bama Tuner, BBK Catted X-Pipes, Ford Racing Sport Axle-Back Exhaust...(Not Done Yet)
Old 01-03-2013, 06:32 PM   #7
Sluder4's Avatar
Sluder4 is unknown around these parts
Attempt to give it some gas. I got bad gas in the past and I had to just rev it at like 3k RPMs for a bit till it burned all the bad stuff out and it worked fine.
But idk if that's it or not. Wouldn't crank I finally gave it had as I darted it and it started up.
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 01-03-2013, 06:33 PM   #8
98StangKid's Avatar
98StangKid is unknown around these parts
Cycle the key a couple of times before actually trying to start it. See if that works.
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 01-04-2013, 05:53 AM   #9
99VSixer's Avatar
Turns out my key had gone bad, when i put the key in the remote it would read it as a theft and disable the fuelpump.
Got new key and all is good now.
Old 01-04-2013, 06:32 AM   #10
1slosix's Avatar
fun lol
04:16 PM
