Timing Chain, sensor, or something else... - Mustang Evolution
Old 01-06-2013, 06:06 AM   #1
ProjectTurboV6's Avatar
Soooo my car on start up struggles to get going and sometimes makes a blowing pop type noise out of the CAI. I took her to Advanced Auto Parts because of the check engine light that randomly came on. His code scanner said it 'could' be the timing chain, timing chain sensor, or something else... I ruled out the chain because if it had slack you could hear that kind of noise. I replaced the sensor... And the problem still occurs. Any help will be very appreciated!
ProjectTurboV6 is offline   Reply With Quote
Old 01-06-2013, 06:51 AM   #2
It's not me, it's you.
primer2tone's Avatar
The timing chain tensioner could still be holding the slack so it's not noisy but it could still be off enough to cause your problem. Do a compression test. If some cylinders psi is too high and some low, it's gotta be the chain.
Old 01-06-2013, 07:31 AM   #3
My dad wants me to also add that once its started and then you shut it off, she fires right up when you turn the key for the second time...
Old 01-06-2013, 09:15 AM   #4
ForsakenProto's Avatar
Possible cam position sensor?
ForsakenProto is offline   Reply With Quote
Old 01-07-2013, 02:18 AM   #5
Is that sensor under the alternator???
Old 01-07-2013, 05:42 PM   #6
What year stang?
Old 01-07-2013, 07:07 PM   #7
1998
Old 01-16-2013, 07:22 AM   #8
So I changed the CPS and it came out in 3 pieces, so that fixed the check engine problem but not the starting issue. I then thought maybe it was the fuel filter so I bought/installed that and still struggles for a little bit to start. So now its down to the fuel pump... Does anybody know what LPH our stock injector system can handle??
Old 01-16-2013, 07:26 AM   #9
What fuel pump are you looking at.
Old 01-16-2013, 07:29 AM   #10
It's an electric granatelli fuel pump that runs 110lph...
Old 01-16-2013, 07:38 AM   #11
How much do you have to spend? Our Stock units i believe put out 190lph, and I've got a walbro unit that's a little over 255lph. Fuel pressure at the rails should be about 40psi at all times
Old 01-16-2013, 07:44 AM   #12
This one is only $70 and the 190lph is around $120 so somewhere in that range. I'm still undecided wither to keep modding the 6er or giver her a 4.6 4v... Regardless a bigger fuel pump is needed
05:01 AM
