Strut Tower Brace Install - Mustang Evolution
Old 01-07-2013, 04:16 PM   #1
1slosix's Avatar
Today i decided to install this little baby...so figured i'd give a little step by step
for those wanting to do this you'll need
-strut tower brace 94-04
-4 nuts & bolts (i used grade 8s for strength)
-socket for nuts
-7mm socket
-flat head screwdriver
-drill bit (for the size of the bolt holes in the STB..mine was 5/16th)
-hack saw blade
have an hour to spare to get this done if you're alone
step 1. remove the weather stripping between the hood and cowl..remove the plastic rear fire wall, and cowl piece with the flat head & 7mm socket
step 2. notch the plastic firewall in the center to allow the STB to mount the rear to the firewall...i used the drill to make starter holes then used a hacksaw blade to cut the piece free.
step 3. test fit the STB with the plastic firewall off...now mark where the holes will be drilled
step 4. now drill out all the holes..this was actually the easiest part of the install lol. if it smokes to much add a bit of motor oil to lube the bit to keep it from over heating
step 5. reinstall the plastic firewall and cowl then refit the strut bar up.
step 6. slide the bolts in through the wheel well and then put the nut on to hold it in place on all corners. once everything is sitting in place good finish tightening it all down....for the rear bolts you can either use a speed nut and set that up while the cowl is off or use a bolt that has an expanding backing to be easy
and you're done...sit back and enjoy the view
(this pic was taken before it was buttoned down)
carving corners like a boss
Old 01-07-2013, 04:18 PM   #2
Awesome, thanks for the write up!! This is something I've been thinking of installing as well.
delff128 is offline   Reply With Quote
Old 01-08-2013, 07:11 AM   #3
Slow03GT's Avatar
Same thing I was about to say. Thanks for the write up.
03 Dark Shadow Grey GT: 03 Cobra Brake Upgrade, H&R Super Sport Springs, Magnaflow Magnapack Catback, Anthracite FR500s with Continental ExtremeContact DW tires all around, Steeda Tri-ax, Maximum Motorsports Full Length Subframe Connectors, plus much more...
Slow03GT is offline   Reply With Quote
Old 01-08-2013, 07:37 AM   #4
It's not me, it's you.
primer2tone's Avatar
Nice!
Old 01-08-2013, 08:25 AM   #5
Mustangman92's Avatar
What exactly does it do for the car?? Just for stability?
Mustangman92 is offline   Reply With Quote
Old 01-08-2013, 08:53 AM   #6
1slosix's Avatar
It keeps the front end from flexing under high cornering situations. Also helps to keep the car flat in turns.
Old 01-08-2013, 12:16 PM   #7
Venomouz831's Avatar
Nice write up! Will be doing this to mine as well
)02 Gt, Founder of WE2G
Old 07-27-2013, 04:12 PM   #8
1lowGT's Avatar
Just bought one today.
Old 07-27-2013, 07:22 PM   #9
Blovett55's Avatar
How's it working?
Take on any sharp turns since, like could you feel less chassis flex and roll
Blovett55 is offline   Reply With Quote
09:42 PM
