popping noise??? - Mustang Evolution
Old 06-24-2008, 03:09 PM   #1
Question popping noise???
yeah...when i make a turn (like at a stop sign) i hear a pop...i remember hearing about the same thing on a previous post, but I can't find it agani...lol didn't know if anyone had an idea of what it is.
girlandherstang is offline   Reply With Quote
Old 06-24-2008, 05:14 PM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: popping noise???
It may be a bad ball joint, strut mount, or tierod end. All may cause that. I'd Probably lean toward ball joint, but that's just a guess.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-24-2008, 06:19 PM   #3
is that pretty important? lol i know some about cars, but not a whole lot.
Old 06-24-2008, 07:00 PM   #4
Scut95's Avatar
yea, thats an important part....you probably should get everything checked out
Old 06-24-2008, 07:59 PM   #5
yea i'll prob. get my dad to check it out when i get my new parts put on. it's such a pain in the butt tryin to get my dad to fix anything. u say u hear a weird noise he just says 'i don't hear anything!' and i'm like well of course u don't yur half deaf and won't get a hearing aid!
Old 06-27-2008, 09:46 AM   #6
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
I noticed when I was changing my suspension my ball joints had tears in them. Anything I should know about replacing them?
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 06-28-2008, 03:46 AM   #7
MonteCitan's Avatar
You'll need a ball joint puller to get 'em out, megax.. aside from that pretty straightforward... soak everything with PB blaster for like a day
As for this post..
Not sure if the new ones are set up the same way... but the steering racks in the 94-04 stangs had bolts through the steering rack then through the subframe or control arm (I can't picture it..) with a bar covering the bolt in the hollow part of the frame (like a sleeve) that bar would creak against the frame when the rack would shift.. removing the bolts and lubing everything up would cure the issue for a year or so.. if not permanently...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-28-2008, 10:16 AM   #8
Region: Iowa
Those bolts go through the k-member. I can't recall if the new ones are the same way or not. I think that they are, but as long as the steering rack bushings aren't damaged or worn, there shouldn't be much creaking going on. As for popping, if it is the steering rack, I'd say those bolts that hold the rack in place probably have come loose a bit and need to be tightened.
Old 06-28-2008, 10:20 AM   #9
thanks for all the help you guys. i'm going to check it out prob. on monday when i put on my new fender wells, since the old ones don't fit with the new bumper. i'll check everything out when i get the wheels off, dad'll be there to check as well incase i might miss seeing something.
Weird popping noise from rear iwannagofast 1996-2004 Mustang GT 1 05-12-2009 12:10 AM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Popping Noise 98StangGT 1996-2004 Mustang GT 8 08-04-2006 11:11 PM
popping the doors!!!!! fast64 Pictures and Videos 9 10-28-2004 03:56 AM
Whats that Popping? bluemustang The Bar 11 10-18-2004 09:03 PM
08:30 AM
