98 v6 what would cause.... - Mustang Evolution
Old 01-10-2013, 08:43 AM   #1
So my 98 has been acting up when I hit 50 or above and let off the gas what would cause it to seem like its braking itself till you hit the gas again and then let off and it does it all over again but if you keep pressure on gas pedal it's fine.
Wildone is offline   Reply With Quote
Old 01-10-2013, 08:49 AM   #2
Mustangman92's Avatar
The e brake lol maybe it has something to do with your brake lines
Mustangman92 is offline   Reply With Quote
Old 01-10-2013, 08:50 AM   #3
nhcowboy's Avatar
1) you are in a lower gear and essentially engine breaking.
2) something is causing parasitic drag.... Brakes, bearings (driveshaft, gearbox, rear end, etc...), Indicating a failure... Check your brakes to see if under normal use, there isn't one that is running exceptionally hot... Touching your wheel will sometimes tell you as unusual brake drag will transfer heat to the wheel... So if one is warmer to the touch... Could be a stuck piston.
3) you're dragging a body under the car
4) you left your drag parachute deployed.
5) I don't know...
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 01-10-2013, 08:55 AM   #4
My vote is option 4 lol
Old 01-10-2013, 01:54 PM   #5
sam62893's Avatar
5) I don't know...
This post made my day
But It sounds like a stuck piston to me
Old 01-10-2013, 02:09 PM   #6
Project Pony's Avatar
I needed a good laugh! I would also take a look at your calipers.
[SIGPIC][/SIGPIC]
Old 01-10-2013, 02:37 PM   #7
Yep that's also a good idea
Old 01-10-2013, 02:37 PM   #8
clogged cats?
Old 01-10-2013, 02:44 PM   #9
Alright ill look at calipers first
02:40 AM
