dies and i dont know why - Mustang Evolution
Old 06-25-2008, 06:39 PM   #1
Region: Nebraska
alright.. my car started runnin like crap a couple weeks or so ago... started runnin really rough and then died... i get it started back up drive down the road maybe a mile or 2 and same thing happens... ive found what i think might be a pattern, whenever the fan would want to kick on... it decides it might not want to run anymore, cooling fan and ac stuff like that... also when it does start running rough one of the turn signals quits working... which totaly blew my mind and is one of the factors i have no freakin clue what is wrong...
im just curious whether anybody has any idea what might be goin on... cuz i dont and i dont really want to let a mechanic here screw me out of more money than i need to lose
burbach is offline   Reply With Quote
Old 07-02-2008, 09:58 PM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: dies and i dont know why
Not all mechanics will screw you, just so you know.
It sounds to me like you have crap plug wires and they are arcing to the block, screwing up your ground connection. Happened to mine once, when one of my wires came out of the loom and melted off the coating on the exhaust manifold. My speedometer and tach started spiking up to max and dropping back to zero and all kinds of fun weird stuff. With out looking at it, that's my guess. Also, could be a problem with the computer. With out having any idea what year or model you're driving, it's pretty hard to guess.
Horse,
ASE Cert. mechanic.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 07-04-2008, 09:41 AM   #3
Region: Nebraska
its an 02.. but those assumptions make sence to me ill see what i can see... i also noticed that one of my headlights is dimmer than the other.. then when it starts runnin rough its out completely... makes me think its a computer problem, when i turn on my brights or something else it gets nasty.. i dont know
Old 07-07-2008, 09:46 PM   #4
Region: Iowa
Headlights, to my knowledge, don't route through the computer at all. More likely it's a ground problem and that's how it's related.
Old 07-07-2008, 10:11 PM   #5
Region: Nebraska
i guess i should have known that.. ill try and figure it out.
Racer dies Scut95 The Bar 7 06-30-2008 08:16 PM
Pavarotti Dies......... Thomas91169 The Bar 11 09-06-2007 07:13 PM
Car dies after driving with a/c on??? username182 1979-1995 Mustang GT 8 06-21-2005 07:10 PM
Reagan Dies at 93 LuvMyGT The Bar 21 06-07-2004 12:30 PM
Man Dies after Winning.... Ken The Bar 8 11-20-2003 08:38 PM
» Members Mustangs
Todd
tjzola
bullet
mrjp64
Add your Mustang
08:17 AM
