14s - Mustang Evolution
Old 01-11-2013, 10:41 PM   #1
Torchredfrankie's Avatar
14s
I want to get my 04 v6 in the 14s what's the next best mods to help me get there nothing big like turbo or SC
I have k&n intake O/R xpipe and a SLP cat back and a 8.8 rear end
Torchredfrankie is offline   Reply With Quote
Old 01-11-2013, 10:44 PM   #2
1slosix's Avatar
do you have a spare 2 grand? check davids build....it's gotten him in the low 14s
carving corners like a boss
Old 01-12-2013, 02:49 AM   #3
davidcseifert's Avatar
Region: Arkansas
Learn to port and polish heads yourself, only way you'll get it for <2 grand anymore, Kyle is holding off his production... And SSM is $$$$
The 14.2 run wasn't even matching my best runs I did at the short tracks, it'll do a lot better now that I can hook
blower/new cam soon
Old 01-12-2013, 03:01 AM   #4
Venomouz831's Avatar
NOS!!!
)02 Gt, Founder of WE2G
Old 01-12-2013, 04:34 AM   #5
03Sixtang's Avatar
Region: Nevada
Im afraid of doing the port/polish myself, I feel like that should be left to a professional, am I wrong?
03Sixtang is offline   Reply With Quote
Old 01-12-2013, 04:46 AM   #6
ProjectTurboV6's Avatar
You could put 4.2 heads onto your car, lighter flywheel, 3.73 or 4.10 rear end gears, rear seat delete, practice shifts/reaction time... You just need to get your power/weight ratio down so you're not pushing so much weight
ProjectTurboV6 is offline   Reply With Quote
Old 01-12-2013, 07:55 AM   #7
Region: Arkansas
4.2 heads are exactly the same as the ones already on his car...
You will not be able to break into 14's without touching the motor in these cars, so keep that in mind OP
blower/new cam soon
Old 01-12-2013, 08:58 AM   #8
Dont 4.2 heads a have a slightly bigger bore/bigger pistons??
Old 01-12-2013, 09:59 AM   #9
Region: Arkansas
-_- the 4.2 bottom end not heads, has the same 3.81" bore but longer stroke of 3.74" (factory 3.8 is 3.3X I think, forgot that one) if you took a 4.2 and 3.8 splitport head and set them side by side you could tell no difference
blower/new cam soon
Old 01-12-2013, 02:41 PM   #10
SN95V600's Avatar
David can you get me the measurements to the pcv lines i need for the windstar intake
SN95V600 is offline   Reply With Quote
Old 01-13-2013, 03:38 AM   #11
Region: Arkansas
I don't have pcv anymore? Lol just buy about 4' of 3/8" vac hose, shouldn't be much waste afterwards, it's cheap so meh
blower/new cam soon
Old 01-13-2013, 07:54 PM   #12
SN95V600's Avatar
Ok so no pcv i can do that im gana leave my iac were it use to be just make that plate thing with two bungs now what about the size of the bung on the bottom of the tb does it matter?
Old 01-13-2013, 08:01 PM   #13
SN95V600's Avatar
David peep my album i uploaded pics of my progress on my intake
Old 01-13-2013, 08:19 PM   #14
Mustangman92's Avatar
What'd you take that intake in your pics off of?
Mustangman92 is offline   Reply With Quote
Old 01-13-2013, 08:32 PM   #15
SN95V600's Avatar
I took the intake off a while back frn a windstar at the junk yard a while back iv been slowly workin on it and been trying to finish it finally had time n money and im almost done to finally install im just cofused on the vac hoses bro i picked up a good piece of the pigtail of the tb wire from a v6 also i need to fabricate a plate for the throtltle i saw one were the guy used the stock piece it reached
Old 01-13-2013, 08:36 PM   #16
How much does the whole swap run?
Old 01-13-2013, 08:39 PM   #17
SN95V600's Avatar
Iv invested 100 little over so far
Old 01-13-2013, 08:42 PM   #18
How difficult is it?
Old 01-13-2013, 08:49 PM   #19
SN95V600's Avatar
Not much just have tools lol im just confused on how the vac hoses go cuz i see that some ppl bypassed only pass. Side valve cover but not driver so yea idk!
Old 01-13-2013, 09:52 PM   #20
Region: Arkansas
i'm assuming you're talking about the 90* fitting like VAP used on the underside of intake behind the tb? they used 5/8" hoses and i can't remember if that was OD or ID of the hose, so it may end up being like a 1/2" bung on the underside not sure, same with the bungs you would have to weld to the iac relocation plate
if you take one off you're suppose to bypass the other side too
blower/new cam soon
Old 01-14-2013, 01:52 AM   #21
SN95V600's Avatar
Oh ok yea see the one i got is smaller then that ok il switch tmrw get you said 4 feet of vac hose should be enough right? And ok yea i already shaved iac port on tb just need to fill in the hole some jb weld
Old 01-14-2013, 12:39 PM   #22
SN95V600's Avatar
Does it matter what size of vac hose i get im going 3/8 for my iac i bought 4 ft of that lol
Old 01-14-2013, 02:42 PM   #23
it can be done, manuals have an easier time by far though, you will need every bolt on as well as a good tune and suspension mods etc and some weight reduction. Stock you are at 15.9 or 16+ seconds so its a LONG hard road.
Old 01-14-2013, 02:53 PM   #24
SN95V600's Avatar
Old 01-14-2013, 04:50 PM   #25
Region: Arkansas
unless stalled auto*
blower/new cam soon
02:17 AM
