Windstar intake - Mustang Evolution
Old 01-12-2013, 02:09 PM   #1
SN95V600's Avatar
Windstar intake
Can i use my stock 3.8 throttle body? Or i have to swap to 65mm? I shaved off the top were the iac should sit can i bypass with out a iac? Lol
SN95V600 is offline   Reply With Quote
Old 01-12-2013, 02:27 PM   #2
03Sixtang's Avatar
Region: Nevada
The 3.8 TB won't bolt up the same, I took the internals of the 3.8 TB and put them in the windstar TB, or I think you can just get the bigger one
03Sixtang is offline   Reply With Quote
Old 01-12-2013, 02:33 PM   #3
SN95V600's Avatar
Ok so i have to get a gt tb frm a 99-04 right? Will the tb connect correctly? For the pcv the bung that goes on the bottom do you know the size of it?
Old 01-13-2013, 09:48 PM   #4
slonison's Avatar
Cool
Needs to be 01-04 GT Throttle body if I remember correctly, because the throttle cable changed 99-00 to 01-04. The place where the throttle cable connects to the throttle body changed. I am not sure what you mean about the PCV bung, but I know that the PCV hose is 5/8".
slonison is offline   Reply With Quote
Old 01-13-2013, 09:53 PM   #5
SN95V600's Avatar
Peep my pics in my album so u can see my progress bro and wat i mean bung is wen u tap into the bottom for the iac im almost done just confused on the vac hoses part i plan on bypass of pcv and also keeping iac in stock location just make a custom plate for iac and just extend tb wire i picked up a pigtail and extra wire from the junk yard today
Old 01-13-2013, 10:11 PM   #6
davidcseifert's Avatar
Region: Arkansas
since you're remote mounting iac you can just shave the top of a mustang tb and use it they bolt up just fine except the iac ports don't line up (not a problem in your case)
gt stays the same from 99-04, it's the sixxer's tb's that change 99-00 and 01-04, since OP's is a 2000 he would have to swap to a gt throttle cable to use their tb
iac hose is 5/8" pcv is a little 3/8" line like factory
blower/new cam soon
Old 01-14-2013, 07:28 PM   #7
Mustangman92's Avatar
What's a good price to pay for the windstar intake manifold
Mustangman92 is offline   Reply With Quote
Old 01-14-2013, 08:11 PM   #8
Region: Arkansas
I paid $35 at local yard
blower/new cam soon
Old 01-14-2013, 10:18 PM   #9
SN95V600's Avatar
Can i use 3/8 for iac instead of 5/8
Old 01-14-2013, 11:23 PM   #10
Region: Arkansas
Need a bigger line, otherwise it'll restrict airflow and screw with idle
blower/new cam soon
Old 01-14-2013, 11:28 PM   #11
I'm about to do this too where is the itemized list of everything you need?
Old 01-15-2013, 03:15 AM   #12
SN95V600's Avatar
****.....lol ok il switch the bungs i bought today tmrw at auto zone for a 5/8 hopefully they switch me the hose size cuz i got 3/8th if not o well extra vaccum hose to have lying around i also need breathers do u kno the size lol
Old 01-15-2013, 05:47 AM   #13
See this is why I want an itemized list haha :p
Old 01-15-2013, 07:14 AM   #14
SN95V600's Avatar
Well
1st-windstar intake
2nd-vaccume hose as you read 5/8 is best for your iac 3/8 is for your pcv
3rd-you need a 90* 1/2 bung for the underside behind the tb
4th-if your gana relocate the iac you must shave the top were it would normally sit also if your going to use your mustang tb you need to shave the iac port check out my photo album you will see my progress
5th you need to extend the tb pigtail and maybe your iac depends were you plan on keeping it if its stock location dnt worry but if your goin to have it nxt to ur c.a.i extend the wire also
Old 01-15-2013, 08:56 AM   #15
What year windstar has the intake we need?
Old 01-15-2013, 09:19 AM   #16
SN95V600's Avatar
96-98 i think
Old 01-15-2013, 12:58 PM   #17
Yours looks sweet you said it was easy right? Do you ever take te motor out or anything... I wanna do it I'm just scared plus my old cai will be useless
Old 01-15-2013, 02:37 PM   #18
What hood are you using your original one
Old 01-15-2013, 06:45 PM   #19
slonison's Avatar
Check my build thread for an itemized list.
Old 01-15-2013, 08:27 PM   #20
slonison's Avatar
Serafina - A 2002 V6 Build *PIC HEAVY*
Old 01-15-2013, 10:59 PM   #21
SN95V600's Avatar
Well since im not using my pcv im just gana cap off the top bung then route it under behind the tb
---------- Post added at 01:59 AM ---------- Previous post was at 01:57 AM ----------
Hopefully get the 2 breathers and the metal piece of aluminum for the iac i wonder what else i could use to rig up a bracket
Old 01-17-2013, 01:43 PM   #22
Can I use my v6 cruise control cable with the gt tb?
Old 01-17-2013, 05:14 PM   #23
SN95V600's Avatar
I broke my over fill tube :'( fuel line i did it good it clears fine the intake is sitting on the lower but i started banging in the tube wit a hammer and yea it messed up were it goes on top of the water pump to begin with i messed up i bent it wrong its not hitting the intake but the tb doesnt clear :/
Old 01-17-2013, 05:20 PM   #24
Where did you get the custom brackets and tubing for the cai? and that sucks...
Old 01-17-2013, 05:29 PM   #25
SN95V600's Avatar
The brackets i made them out of squares of sheet metal check my photo album so now i need to find one i looked at both local junk yards an they were yanked already!!!! :/ the tubbing is a reg cai if u look at it its jst that the straight part has to coming from the 90* then that little bend it has is were its resting on the radiator hose u kno
Old 01-17-2013, 05:32 PM   #26
How did you cut the metal? If anyone was willing to make those brackets I would pay a fee plus shipping... i dont know what i would do it myself with
Old 01-17-2013, 05:47 PM   #27
SN95V600's Avatar
Some metal cutting shears electrical lol it made the cutting so easy lol
Old 01-17-2013, 05:56 PM   #28
You made the iac relocation, coil bracket, and the throttle cable bracket like that?
Old 01-17-2013, 06:17 PM   #29
slonison's Avatar
Mustangman92, VAP still sells the brackets...
Old 01-17-2013, 06:21 PM   #30
SN95V600's Avatar
Sort of yes and vap does have them i wish he haf the tubbing a little cheaper
Old 01-17-2013, 06:35 PM   #31
They still sell them where I didn't see them
Old 01-17-2013, 07:02 PM   #32
slonison's Avatar
VAP Auto - Windstar Kit
Scroll to the bottom
Old 01-17-2013, 10:51 PM   #33
Good stuff... So far I got the intake, gt tb, iac relocation, coil pack holder (I assume it works for the tb cables too) and the agr adapter... So I need to know the house width and lengths I need as well as the hardware I might need and I guess gaskets as well
---------- Post added at 12:51 AM ---------- Previous post was at 12:46 AM ----------
I realize they are probably somewhere but if you could just point out the components I'm missing and hose sizes I'd be really grateful thanks
Old 01-18-2013, 05:48 AM   #34
And going off that can you use the gaskets already on the car or is it necessary to but new ones
Old 01-18-2013, 07:09 AM   #35
Also am I correct in assuming that the elbow joint vap tells you to place on the lower side of the windstar is for iac relocation
07:17 AM
