Different kind of exhaust question! - Mustang Evolution
Old 01-14-2013, 01:18 AM   #1
austinknoll's Avatar
So I I want my car louder but I have a big problem. Normally I would just go out and buy an off road h or x but i have a custom welded cat back done by a shop and a mid pipe wouldn't bolt up for obvious reasons. I live in California so smog is a PITA. What should I do?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 01-14-2013, 07:02 AM   #2
Crowned1's Avatar
do you have a mid pipe at all right now? i dont see why it wouldn't work. it would just take some welding work. you're right on track for going with an off-road mid pipe. but if it is as strict as say it is then i wouldn't bother taking the cats off. have you looked into high flow cats?
Crowned1 is offline   Reply With Quote
Old 01-14-2013, 09:43 AM   #3
I just have the stock cats on there and he welded it on right past the second cats. He said he can get me CA legal cats installed and everything for $250 each.
65 Mustang coupe
Old 01-14-2013, 09:57 AM   #4
Crowned1's Avatar
so if they're welded behind the second cats a mid pipe would fit just fine as long as the piping is the same size. I'd go with a prochamber or just go with some LT headers. i wouldn't touch the cats because the ones on your car right now are "legal cats" ha.
Old 01-16-2013, 12:18 PM   #5
But I don't know how to weld and my exhaust shop won't weld in anything illegal in California
65 Mustang coupe
Old 01-16-2013, 12:35 PM   #6
Purchase two high flow cats & a ProChamber, they will weld it in place and you will love it.
Old 01-16-2013, 01:03 PM   #7
Prochamber is better than just a H? I was going to have them weld in an H.
65 Mustang coupe
Old 01-16-2013, 01:58 PM   #8
1slosix's Avatar
depends on the sound you want...a prochamber is quieter then an h pipe when cruising but at WOT it's quite loud.
carving corners like a boss
Old 01-16-2013, 03:37 PM   #9
Crowned1's Avatar
find a different a exhaust shop lol
Old 01-17-2013, 12:55 PM   #10
ProChamber information: Patent US5740671 - Balance box exhaust accelerator - Google Patents
You can Google the ProChamber on different V6 engines. It was made to collect & then accelerate exhaust gasses. The performance is nice, (gained 10HP with it & LT headers) but it sounds deep and attractive to me, personally.
*A set of common metal high flow cats should pass Ca. emmisions no problem at all (California emissions documentation should accompany the cats)
Old 01-17-2013, 07:35 PM   #11
lemons95's Avatar
purchase two mid pipes, one with cats and one without cats.
have them bolted on not welded on and every time you need to smog just swap the mid pipes.
Old 01-20-2013, 06:20 AM   #12
FYI: California rated cats- http://www.summitracing.com/parts/mp.../model/mustang
exhaust
09:15 PM
