H-pipe conversion - Mustang Evolution
Old 01-14-2013, 01:27 PM   #1
TM2189's Avatar
H-pipe conversion
What's the average price for an h-pipe conversion for my exhaust? And where can I get it gone.
TM2189 is offline   Reply With Quote
Old 01-14-2013, 01:56 PM   #2
ProjectTurboV6's Avatar
The part, if bought online, is $140. To get someone to wield that in could be 50-100 more just in labor. Do you already have a cat back system?
ProjectTurboV6 is offline   Reply With Quote
Old 01-14-2013, 02:41 PM   #3
you dont require an H pipe for the 3.8L due to its an even fire motor, you can use one but you dont have to. You can have someone cut off the Y pipe and just run a pipe on each side back. The issue is bolting/unbolting may not be possible unless they weld in flanges.
Old 01-14-2013, 07:57 PM   #4
Dantheman94's Avatar
I'm running a pacesetter gt cat back conversion kit right now. It basically just keeps your cats intact and turns into an behind them for a gt cat back system. Again not a hole lot of performance but it sounds really good compared to the y pipe
Dantheman94 is offline   Reply With Quote
Old 01-16-2013, 11:42 PM   #5
Fourloko530's Avatar
Do u have to have a gt cat or can u just weld them to the mufflers
---------- Post added at 12:42 AM ---------- Previous post was at 12:41 AM ----------
Wouldn't the noise b diffrent thow
Fourloko530 is offline   Reply With Quote
Old 01-16-2013, 11:48 PM   #6
1slosix's Avatar
yes tone will change along with a slight shift in the power band but you don't have to have any midpipe.
carving corners like a boss
Old 01-16-2013, 11:58 PM   #7
So can i just weld my h pipe to my exhaust
Old 01-17-2013, 12:50 AM   #8
1slosix's Avatar
if you have a dual exhaust now then yeah but if it's either a single exhaust or y pipe dual exhaust not as simple
Old 01-17-2013, 01:00 AM   #9
Well what if u want it dump
Old 01-17-2013, 05:36 AM   #10
1slosix's Avatar
Old 01-17-2013, 11:25 AM   #11
When cutting off the y pipe on a 98, how big is the outside diameter of the stock pipe??
Old 01-17-2013, 12:20 PM   #12
austinknoll's Avatar
The pipe size after the cat is 2.5" and after t turns into a single exhaust it's 2.25 I believe
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 01-17-2013, 12:30 PM   #13
That would be awesome if you're right, because the cat back I have is 2.5" as well so all I need is 2.5" piping to stretch from the cats to the mufflers for a true dual exhaust ) then I search for a 4.2 to rebuild
12:00 PM
