Awkward question - Mustang Evolution
Old 01-14-2013, 08:36 PM   #1
Brandfire's Avatar
Awkward question
Does anyone an easy way to remove the rubber exhaust hangers from a 97 mustang?
Brandfire is offline   Reply With Quote
Old 01-14-2013, 08:38 PM   #2
zinc_yellow's Avatar
Region: New Mexico
The hangars or the muffler from the hangar?
zinc_yellow is offline   Reply With Quote
Old 01-14-2013, 08:40 PM   #3
Brandfire's Avatar
The hangers from the frame...I'm goin from stock exhaust to straight pipes
Old 01-14-2013, 09:05 PM   #4
Region: New Mexico
Ohh gotcha
Old 01-14-2013, 09:11 PM   #5
1slosix's Avatar
i use a claw hammer to pry up and off the metal piece
carving corners like a boss
Old 01-15-2013, 10:17 AM   #6
Brandfire's Avatar
Alright sounds good I'll give it a try
Old 01-15-2013, 10:42 AM   #7
usually stock they pop off somewhat easy, but mine are a nightmare with the fatter ends on my aftarmarket exhaust.
Old 01-15-2013, 10:45 AM   #8
Brandfire's Avatar
Yea I think they'll come off with a little white lithium grease and a claw hammer
Old 01-15-2013, 03:31 PM   #9
Brandfire's Avatar
Ok I got the hangers off but ran into another problem I can't get the exhaust past the axle
Old 01-15-2013, 06:35 PM   #10
1slosix's Avatar
Yeah i always have to cut the pipe off right where it would connect to an aftermarket muffler to get the pipe out
Old 01-15-2013, 06:41 PM   #11
Brandfire's Avatar
Is there any way besides cutting it?
Old 01-15-2013, 06:58 PM   #12
It's not me, it's you.
primer2tone's Avatar
Disconnecting the shocks should drop your axel a few more inches. Maybe that'll give you the clearance needed to get them out. Or you could take it to a shop and have them put it on a lift.
Old 01-15-2013, 06:58 PM   #13
slonison's Avatar
I used WD40... if it's getting the hanger out of the Rubber.
slonison is offline   Reply With Quote
Old 01-15-2013, 07:30 PM   #14
Brandfire's Avatar
Yea the WD40 worked the best and I think I might try the shock idea it only needs to clear by one more inch
Old 01-15-2013, 07:34 PM   #15
WD40 those shock bolts before you try to break them loose. I've stripped some out in the past.
Old 01-15-2013, 10:10 PM   #16
1slosix's Avatar
pb blast > wd40 lol
03:49 PM
