Need help with naming a part - Mustang Evolution
Old 01-15-2013, 09:50 AM   #1
BamaStang93's Avatar
The other day I went over a speed bump and something happened to something by the tire (you can see in the pictures, idk the name of the part) but has this happened to you before? How much was the part to fix it and what is the part called? I don't want to go to a local shop/pepboys because I know they're gonna want $250+ to fix it and I'd rather just fix it myself.
ID:	85808   Click image for larger version
BamaStang93 is offline   Reply With Quote
Old 01-15-2013, 09:55 AM   #2
Dgerow12's Avatar
That is a sway bar end link. They are about 20 bucks or so a piece at local part stores and depending on how hard it is to take the old one off are about 25 mins to replace. I recommend replacing both sides at the same time. They are obviously weakened and adding a new stiff one will increase the likelihood of the other one breaking
Dgerow12 is offline   Reply With Quote
Old 01-15-2013, 10:05 AM   #3
Thank you so much. That really helped me out! And I think I'm going to do what you said and get the other one replaced. It looks like the previous owner didn't bother to get new ones so I'm dealing with it. But hey, any excuse to work on the Stang is good enough for me!
---------- Post added at 11:05 AM ---------- Previous post was at 11:03 AM ----------
Say I were to take it to a shop , don't you think they would over charge for something this simple?
Old 01-15-2013, 10:08 AM   #4
Dgerow12's Avatar
No problem. Also after you get the new ones on climb under and grab the sway bar and try to wiggle or move it. If there's movement in the sway bar then your bushings will also need replacement
---------- Post added at 01:08 PM ---------- Previous post was at 01:07 PM ----------
Yea most shops would. I find it better to figure out what needs to be done and then go to a few shops to get prices. They can't over charge to much if you know what your talking about
Old 01-15-2013, 10:15 AM   #5
Well armed with this new knowledge I'm just going to low ball them. If that doesn't work then me and my buddy will tackle it ourselves.
Old 01-15-2013, 10:30 AM   #6
1slosix's Avatar
Just do it yourself..its a 10 min job lol..takes two wrenches
carving corners like a boss
Old 01-15-2013, 10:40 AM   #7
Dgerow12's Avatar
Yes as long as they aren't rusted together like min were when they broke
Old 01-15-2013, 11:56 AM   #8
1slosix's Avatar
if you ever have a rusted end link just cut it in half and knock the bottom through with a hammer if it just doesn't drop on it's own
Old 01-29-2013, 10:54 AM   #9
Just wanted to update y'all . Simple install, it took 15 minutes. Got a pic below
ID:	88154   Click image for larger version
Old 01-29-2013, 11:02 AM   #10
2300turboford's Avatar
Get Polly urethane end links
---------- Post added at 01:02 PM ---------- Previous post was at 01:01 PM ----------
Nvm looks like u already did
04:28 PM
