mustang Turns off in idle, right after turning on - Mustang Evolution
Old 06-29-2008, 08:57 PM   #1
my 94 mustang will not stay running for more then a couple seconds, ive checked the mass airflow sensor & i really am stuck & looking for help. any suggestions? :damnit:
DG_Aviles32 is offline   Reply With Quote
Old 06-29-2008, 09:36 PM   #2
Re: mustang Turns off in idle, right after turning on
is yur idle set real low?
girlandherstang is offline   Reply With Quote
Old 06-29-2008, 09:47 PM   #3
how wud i check my idle setting?
Old 06-29-2008, 09:49 PM   #4
my dad just usually tweaks with it, turns it up a tad and if it sounds like where it needs to be then he leaves it. just gotta make sure not to rev it up too much.
Old 06-29-2008, 09:51 PM   #5
if u need specifics on how to do that simplyorange or kyle or someone could help u figure that out. lol i was just making the suggestion that that might be what was wrong. my mom's car had the same problem and somehow the idle had gotten real low. i know it's not the same by no means but my four-wheeler was the same way. a real pain in the butt.
Old 06-29-2008, 10:49 PM   #6
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Could be a problem with the Idle Air Control Motor. That would be way more likely, I think.
If you give it some throttle and rev it up, does it stay running? And if that works, once the engine is warm does it stay running by it self? If so, the IAC is probably bad. I had a problem with that on two different '00 mustangs and several ford trucks. Seems to be sort of a problem area with them.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-29-2008, 11:32 PM   #7
I tried cleaning IAC & everything looked clean, wen i rev the motor the car stays running but once i let the gas go it just drops,& dies. the engine was warm when i was trying this also. this problem happened all of a sudden. thanks for the suggestion ill be checking that out tomorrow.
Old 06-30-2008, 04:08 PM   #8
it was a pcv valve unhooked from the intake manifold to the plenum.. i was gunna buy a new IAC but saved 80 bucks & fixed a simple problem =]
Missing Girl Turns out to be secret porn star Brent The Bar 9 12-01-2007 05:21 PM
e-brake light turns on while accelerating 1997grnstang Pre-2005 V6 Mustang 6 10-22-2006 12:31 PM
so as it turns out, God DOES hate me jimmy_beaner The Bar 14 06-15-2005 09:20 PM
Someone turns 21 today....... Brent The Bar 8 04-19-2004 07:31 AM
04:30 AM
