Well put the stang back together...... - Mustang Evolution
Old 01-20-2013, 01:54 PM   #1
SN95V600's Avatar
I guess on my next engine that i build il build the intake on it as well :/ sucks i couldnt finish the swap id luv to see it rocking a windstar intake :/
Thats what i broke some jb weld hopefully it buys me some time ford oem-$130.00
SN95V600 is offline   Reply With Quote
Old 01-20-2013, 02:01 PM   #2
Mustangman92's Avatar
You broke it trying to do the windstar swap?
---------- Post added at 04:01 PM ---------- Previous post was at 03:59 PM ----------
What happened
Mustangman92 is offline   Reply With Quote
Old 01-20-2013, 04:18 PM   #3
slonison's Avatar
I did the same thing...
Where the coolant pipe goes into the water pump...
slonison is offline   Reply With Quote
Old 01-20-2013, 04:22 PM   #4
Oh ya I saw that slo did you ever get yours fixed
Old 01-20-2013, 04:46 PM   #5
slonison's Avatar
Covered it in JBweld... though I'm still leaking somewhere...
Old 01-20-2013, 10:11 PM   #6
SN95V600's Avatar
I ran it today wrking just fine i parked it on a slab like always lets see if she leaks she hadsnt so far though
Old 01-21-2013, 11:34 PM   #7
davidcseifert's Avatar
Region: Arkansas
Take tube off and have it welded up..
You can replace sections of the hard pipe with soft radiator hose (of the same size of course) to make it flexible and be out of the way
blower/new cam soon
Old 01-22-2013, 01:35 PM   #8
SN95V600's Avatar
It should hold hold up till i get nxt engine
06:22 PM
