is the radiator also a transcooler? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Old 01-20-2013, 11:30 PM   #1
lemons95's Avatar
lemons95 is unknown around these parts
I found out that I was leaking trans fluid.
I thought it was motor oil or power steering fluid since it was near the front.
but if the radiators also a transcooler that's probably where the leak is at.
is there a common place that wears out faster.
Me and my dad haven't had a chance to look at it yet.
Old 01-21-2013, 12:44 AM   #2
1slosix's Avatar
1slosix is just getting started.
check the plastic headers on the radiator
carving corners like a boss
Eibach Strut Tower Brace - Rear Shock Tower Brace - GT Rear Sway - Goodridge Gstop SS lines - SR Performance Springs - Sensa-trac Shocks - Mac Prochamber - Borla Stinger 2.5" Mandrel Catback - K&N - Torqthrust Wheels wrapped in Kumo's - TB Spacer - HIDs & Other Visual Goodies
Old 01-21-2013, 11:32 PM   #3
davidcseifert's Avatar
davidcseifert is unknown around these parts
Yes for automatic cars they have a small cooler built into the side of radiator, if it's leaking now is a good time to upgrade to an independent cooler mounted up front, unless of course it's leaking into the coolant also then the radiator will have to be replaced
SSM S3 heads, P&P lower, comp 218/226 cam, 4.2 bottom end, 3k stall, flow 40's, O/R x-pipe, Pacesetter lt's, SCT xcal2 (93 Ortizperformance tune), Windstar upper, 65mm tb, CAI, FRPP T-lok, 3.73's, SFC's, cut factory springs, KYB shocks/struts, MM LCA's
Sponsored by Ortiz Performance, great tunes at a good price!
08:10 AM
