01-23-2013, 07:38 PM
#1 | | Registered User
| Random plug
Anyone know what this plug does? This is under my back seat on the passenger side |
01-23-2013, 07:49 PM
#2 | | Registered User
If I had to guess, it would be something for the convertible model
01-23-2013, 07:52 PM
#3 | | Registered User
| Quote:
Originally Posted by sam62893 If I had to guess, it would be something for the convertible model | Yeah that's what I'm thinking |
01-23-2013, 07:53 PM
#4 | | Registered User
I think that it's because they make the car small electrical parts universal to save money
01-24-2013, 12:19 PM
#5 | | Registered User
Mine is not a convertible but I have those, and it is plugged in, thinking its the abs sensor power.. Does your car have abs? I'll trace the wire when I get home and see
SSM S3 heads, P&P lower, comp 218/226 cam, 4.2 bottom end, 3k stall, flow 40's, O/R x-pipe, Pacesetter lt's, SCT xcal2 (93 Ortizperformance tune), Windstar upper, 65mm tb, CAI, FRPP T-lok, 3.73's, SFC's, cut factory springs, KYB shocks/struts, MM LCA's
Sponsored by Ortiz Performance, great tunes at a good price!
01-24-2013, 01:33 PM
#6 | | Registered User
If im correct, it should be for if your car has a mach 460 sound system. Theres a second set of speakers above the lower 2 in the back seating area that those supply power to.
01-24-2013, 01:57 PM
#7 | | Registered User
| Quote:
Originally Posted by davidcseifert Mine is not a convertible but I have those, and it is plugged in, thinking its the abs sensor power.. Does your car have abs? I'll trace the wire when I get home and see | Nah I don't have abs  ---------- Post added at 02:57 PM ---------- Previous post was at 02:56 PM ---------- Quote:
Originally Posted by ForsakenProto If im correct, it should be for if your car has a mach 460 sound system. Theres a second set of speakers above the lower 2 in the back seating area that those supply power to. | Oh okay idk  lol but I have stock stereo
01-24-2013, 02:44 PM
#8 | | Registered User
| Quote:
Originally Posted by Xaperez100 Oh okay idk  lol but I have stock stereo | Does your door have speakers that read Mach 460? That's how you can tell. Or the speakers in the back have some metal mesh that says Mach 460 as well.
01-24-2013, 02:59 PM
#9 | | Registered User
| Quote:
Does your door have speakers that read Mach 460? That's how you can tell. Or the speakers in the back have some metal mesh that says Mach 460 as well. | Yeah no I have the regular system I mean I put in aftermarket ones but no I don't have the Mach
01-24-2013, 04:28 PM
#10 | | Registered User
The wiring harness for both stock and mach 460 equipped cars. The mach cars use those plugs, while the stock cars just leave it unplugged
01-24-2013, 04:43 PM
#11 | | Registered User
| Quote:
Originally Posted by ForsakenProto The wiring harness for both stock and mach 460 equipped cars. The mach cars use those plugs, while the stock cars just leave it unplugged | Could I use that plug for something else?  anything really? Cause wouldn't that plug still be powered?
01-24-2013, 04:47 PM
#12 | | Registered User
You could possibly find a wrecked car with a mach setup and transfer the amp and speakers over
01-24-2013, 04:54 PM
#13 | | Registered User
| Quote:
Originally Posted by ForsakenProto You could possibly find a wrecked car with a mach setup and transfer the amp and speakers over | Oh okay hmm ill check it out:p
01-24-2013, 07:17 PM
#14 | | Legacy Member
It's ABS sensor plug, if you pull up the "carpet" in that area and the other side you will find a rubber grommet going through the floor pan.
Non Mach cars have 0 of the wiring necessary, trust me, I've put a 460 system in a non-equipped car, was not fun.
Mine: -03 SB Cobra vert- 2552 of 5082 Born 02/25/03
Our's: 90 7up vert - new project-07 DSG Focus -DD 335 |
01-24-2013, 07:40 PM
#15 | | Registered User
| Quote:
Originally Posted by lowflyn It's ABS sensor plug, if you pull up the "carpet" in that area and the other side you will find a rubber grommet going through the floor pan.
Non Mach cars have 0 of the wiring necessary, trust me, I've put a 460 system in a non-equipped car, was not fun. | Oh okay lmao thanks! Keeps going back and forth:p so I could abs? If I wanted lol
01-24-2013, 07:43 PM
#16 | | Legacy Member
No, it's more than just a plug, ecu has to have the abs system programmed in. Not to mention the brake lines are slightly different.
This is simply a sensor that connects to the rear axle to check for any slippage, works in tandem with traction control if I remember correctly.
