cheapest way to lower - Mustang Evolution
Old 01-25-2013, 03:11 PM   #1
V6in's Avatar
I have done zero to my suspension and have 18x9 and 18x10 saleen wheels. I wanna lower it but $ is tight right now. Any suggestions?
V6in is offline   Reply With Quote
Old 01-25-2013, 03:12 PM   #2
1slosix's Avatar
cut your springs...i've done a lot of cut sets and for a few hours of work you'll be very happy
carving corners like a boss
Old 01-25-2013, 03:17 PM   #3
1slosix's Avatar
both of these i cut 1.25 coils off the front an 1 coil off the back and i did remove the ISOs...but you can leave them in if you want to raise it by about a 1/4"
Old 01-25-2013, 03:19 PM   #4
V6in's Avatar
What do I use to cut them?
Old 01-25-2013, 03:22 PM   #5
Venomouz831's Avatar
Yea cheapest it to cut them but still springs aren't that expensive.
)02 Gt, Founder of WE2G
Old 01-25-2013, 03:23 PM   #6
V6in's Avatar
There has to be something bad about cutting them. Otherwise why doesn't everyone do it ?
Old 01-25-2013, 03:32 PM   #7
1slosix's Avatar
nothing bad at all acutally...i've cut i think 10 sets now. the reason most buy lowering springs is
1. have heard horror stories but have no rear experience
2. want a stiffer riding car for handling
3. don't have the patience to cut
4. just like the ease of popping new springs in
cut springs are great for drag racing btw...really good weight transfer when you launch
now i will say idiots that heat springs to lower them are the root to alot of cutting confusion...heating a spring will ruin its temper. so always use a angle grinder with a metal or bi-metal cutting wheel to cut the coil off
Old 01-25-2013, 03:40 PM   #8
V6in's Avatar
Is it difficult to actually take the springs out and put them back in ? Also would a shop do all of this ? Cut and install oem springs
Old 01-25-2013, 03:51 PM   #9
1slosix's Avatar
i don't think shops will do it...but it's not hard..my first time me and a friend took all four corners out, cut, and installed in 3 hours...that's with us not knowing a thing about how to remove anything. now i can do it in half that time...
here's a good general write up for ya...
The Complete How To Cut Your Stock Springs Thread - SVTPerformance
Old 01-25-2013, 03:58 PM   #10
V6in's Avatar
Thx a bunch
Old 01-25-2013, 03:59 PM   #11
1slosix's Avatar
no problem...if later down the road you decide you want a stiffer ride then upgrade to lowering springs
Old 01-25-2013, 03:59 PM   #12
1slosix's Avatar
btw i'd say with your wheels to be safe cut 1 coil all the way around and leave ISOs till you know you can pull them
Old 01-25-2013, 04:02 PM   #13
V6in's Avatar
It wouldnt hurt to paint them red while I'm at it would it?
Old 01-25-2013, 04:02 PM   #14
The springs?
Old 01-25-2013, 04:07 PM   #15
V6in's Avatar
Ya
Old 01-25-2013, 04:09 PM   #16
Yea you can if you like
Old 01-25-2013, 04:17 PM   #17
V6in's Avatar
I just figured why not, my brake calipers are red. Maybe add somethin lol
Old 01-25-2013, 04:17 PM   #18
Yea just careful when cutting
Old 01-25-2013, 04:29 PM   #19
V6in's Avatar
Ya it won't be for a while. Wait for it to get warmer.
Old 01-25-2013, 06:00 PM   #20
I don't want to hijack the thread... But if you lower say about 2 inches on all 4 then how long would the stock shocks last? I know that for a smoother ride you should change the shocks, but will you be able to lower it a lot without changing the shocks for a while? And would it be best to take out the ISOs or leave them in?
Old 01-25-2013, 06:06 PM   #21
Crowned1's Avatar
take the ISOs out and wrap tape around them. But with a 2 inch drop I'd say leave them in.
Crowned1 is offline   Reply With Quote
Old 01-25-2013, 06:58 PM   #22
03Sixtang's Avatar
Region: Nevada
Your stock shocks won't last too long with two inches
03Sixtang is offline   Reply With Quote
Old 01-25-2013, 07:44 PM   #23
1slosix's Avatar
i don't see them holding up to well..on 1.5" though my last cars oem shocks held up for over a year...which at the time they are between 5-6 years old so not bad for old shocks
08:24 PM
