Trouble changing gears - Mustang Evolution
Old 01-28-2013, 10:27 AM   #1
Crowned1's Avatar
So i have an automatic, it has 104,000 miles on it and when I'm driving it hesitates to change gears. I'll be driving and the tachometer is stuck so i have to give it some gas for it to pick up and change. Sometimes it even feels like the car is slowing down then changes gears. What could be causing this? Also, whenever i turn my steering wheel to the right there is a clicking sound and when i turn it back, what is that? thanks!
Crowned1 is offline   Reply With Quote
Old 01-28-2013, 11:02 AM   #2
sprdave's Avatar
Well,when was the last time you changed the transmission fluid and filter?Have you recently had over heating problems?I sounds like it's slipping and thats bad.Changing the filter and using synthetic transmission fluid might fix it possibly.Does your rpms increase, without an increase
in your speed?
sprdave is offline   Reply With Quote
Old 01-28-2013, 11:29 AM   #3
1slosix's Avatar
Flush and fill...use a good non slip conditioner too..see how that works out
carving corners like a boss
Old 01-28-2013, 01:32 PM   #4
Crowned1's Avatar
in your speed?
honestly couldn't tell you. i bought the car at 97k and do you mean when the car is idling?
07:55 PM
