Foggy headlight? - Mustang Evolution
Old 01-29-2013, 03:51 PM   #1
Brennix91's Avatar
Foggy headlight?
Hey! My left headlight is getting foggy and my right one looks brand new! What can I do to remove that fogginess?
Brennix91 is offline   Reply With Quote
Old 01-29-2013, 03:54 PM   #2
Slp_loudmouth's Avatar
Take it out put a peice of wet cardboard under it and bake it at like 125
Slp_loudmouth is offline   Reply With Quote
Old 01-29-2013, 04:10 PM   #3
1slosix's Avatar
Toothpaste
carving corners like a boss
Old 01-29-2013, 05:01 PM   #4
Brennix91's Avatar
Originally Posted by 1slosix View Post
Toothpaste
What do you mean toothpaste?
Old 01-29-2013, 05:08 PM   #5
1slosix's Avatar
I mean buff the heck out of your foggy headlight with cheap toothpaste...usually colgate
Old 01-29-2013, 05:15 PM   #6
Brennix91's Avatar
Lol have you ever heard off people doing it with really fine grit sand paper? Like 900 or 1000 grit?
Old 01-29-2013, 06:50 PM   #7
Used the 3m kit. for. 30 dollars and about an hours Labour and they look new
Dugaldrob is offline   Reply With Quote
Old 01-29-2013, 09:05 PM   #8
Xaperez100's Avatar
Drill a hole in the bottom a very small one to make sure that water isn't staying in there.
Cause the water In the headlight can cause moisture. And the toothpaste thing works but it could be happening from the inside.
Xaperez100 is offline   Reply With Quote
Old 01-29-2013, 10:30 PM   #9
1slosix's Avatar
If you use sand paper then make sure you three step it and only wet sand. So 500 grit...1000 grit...2000 grit. All wet sand..then buff with polishing compound...same thing as buying a 3m kit but alot cheaper
Old 01-30-2013, 02:20 AM   #10
Brennix91's Avatar
Ill try that tooth pasts thing next time it's warm out side!
Old 01-30-2013, 06:41 AM   #11
Project Pony's Avatar
+1
[SIGPIC][/SIGPIC]
Old 01-30-2013, 08:41 AM   #12
Dantheman94's Avatar
Use a little bit of brake fluid and wipe on the lense (not the paint!) and it'll clear it right up. If your talking about condensation the just let it dry out and reseal it
Dantheman94 is offline   Reply With Quote
09:51 AM
