weird throttle noise - Mustang Evolution
Old 01-31-2013, 09:13 PM   #1
joey18's Avatar
alright when i hit the thottle there is a weird noise and the exhaust note doesnt sound the same... i dont know how to describe it but it sounds like a go kart or a tapping.. it gets louder as i speed up and loud when im in a high gear...
when i lift the hood it sounds like its coming from near the thottle body
it kinda makes me mad because i just bought the car and theres no warranty:/
---------- Post added at 11:13 PM ---------- Previous post was at 11:10 PM ----------
heres a short video..
joey18 is offline   Reply With Quote
Old 01-31-2013, 09:29 PM   #2
BloodRedStang's Avatar
Is the sound coming from the engine itself? Or somewhere back behind?
It sounds to me like an exhaust leak, maybe a bad exhaust gasket.
BloodRedStang is offline   Reply With Quote
Old 02-01-2013, 06:34 AM   #3
Spencerb102's Avatar
+1 on the head gasket. Same thing happened to mine. My suggestion would be to get a mechanics stethoscope and find exactly where it's coming from. There's so many different noises going on under the hood it's hard to pick one out and know where it's coming from without a stethoscope
Spencerb102 is offline   Reply With Quote
Old 02-01-2013, 07:44 AM   #4
joey18's Avatar
Well i dont think itd be a head gasket, because theres no smoke and the oil look fine
Old 02-01-2013, 08:04 AM   #5
The grim reaper's Avatar
Does it kinda sound like like a low pitch howl I've got the bbk one piece throttlebody and it makes a low howl
The grim reaper is offline   Reply With Quote
Old 02-01-2013, 08:19 AM   #6
Rapid ticking noise?
Old 02-01-2013, 08:22 AM   #7
joey18's Avatar
No everythings stock, theres a video in the op
Old 02-01-2013, 08:34 AM   #8
I just watched the vid I dident see it the first time I read it I had a Chevy blazer once that intake gasket went out sounded real similar to that wasnt broke in a place by a water jacket so no Antifreeze any where j
---------- Post added at 10:29 AM ---------- Previous post was at 10:27 AM ----------
And it's deffently coming from the throttle body kinda sounds like a donut gasket be
---------- Post added at 10:30 AM ---------- Previous post was at 10:29 AM ----------
[QUOTE="The grim reaper;1505687"]I just watched the vid I dident see it the first time I read it I had a Chevy blazer once that intake gasket went out sounded real similar to that wasnt broke in a place by a water jacket so no Antifreeze any where j
And your sure it's deffently coming from the throttle body kinda sounds like a donut gasket where the header meets the down pipe
---------- Post added at 10:34 AM ---------- Previous post was at 10:30 AM ----------
You can stick you hand down where the header hits the down pipe when the motors cold of corse have some one rev it up you should be able to feel the exhaust coming out if that's what it is
Old 02-01-2013, 10:51 AM   #9
joey18's Avatar
Also there no lights coming up on the dash and the car drives good still... i feel like my car looks awesome but sounds like im driving a hoopty honda..
Old 02-01-2013, 03:10 PM   #10
I'm really thinking its an exhaust leak from somewhere.. check for exhaust leaks on rev like the guy above suggested and let us know.
Old 02-01-2013, 04:41 PM   #11
joey18's Avatar
The other day i notice the ac drain hits the exhaust could that cause any harm?
Old 02-01-2013, 10:35 PM   #12
Ac drain? Is it a hard line hitting the exhaust? If so, it could possibly be knocking on the exhaust at rev... seems kinda flimsy but its possible, may explain why you don't hear it when its idling
Old 02-02-2013, 12:43 AM   #13
Those hard lines can be bent a little bit just be carefull and you can get it off there prolly not good for a line that gets super cold to touch somthing that hot could cause the line to burst I watched the clip a few more times I'm with blood I'm 90% sure it's an exhaust leak it's the manifold gasket or donut gasket
Old 02-02-2013, 12:52 AM   #14
1slosix's Avatar
When you say a/c drain do you mean a line or the drip area...because the drip on a 99-04 causes a common manifold crack
carving corners like a boss
Old 02-02-2013, 01:06 AM   #15
What are the 99-04 manifolds made of? Cast iron?
Old 02-02-2013, 01:27 AM   #16
Venomouz831's Avatar
Yea cast iron and most likely a cracked manifold
)02 Gt, Founder of WE2G
Old 02-02-2013, 09:34 AM   #17
joey18's Avatar
@1slosix yeah the drip area the other day i got out and heard a sound like water steaming but drips, it was on the passagnger side dripping on the exhaust, my old sixxer used to drip straight to the ground
Old 02-02-2013, 09:58 AM   #18
Your passenger manifold is cracked/broken at the collector flange. Best bet is buy a pair of 94-98 manifolds from a junk yard.
Common issue with these cars.
Old 02-02-2013, 11:52 AM   #19
1slosix's Avatar
or time to go with some LTs just need to get the exhaust reworked a bit
Old 02-02-2013, 12:00 PM   #20
joey18's Avatar
I wish but i gotta pay the car payment coming up... i just wanna get it good and running.. can it just be taken to a exhaust shop and be welded?
Old 02-02-2013, 12:05 PM   #21
1slosix's Avatar
depending on the crack yes or no...only way to know for sure is to have it looked at
Old 02-02-2013, 04:31 PM   #22
joey18's Avatar
I checked out a few places and they all said from the start i need to buy a new header and they cant weld it and none of them looked at it
Old 02-02-2013, 04:51 PM   #23
1slosix's Avatar
Wow were they exhaust shops? My locals will weld them. Tell them its not a header but a cast manifold. Then if they still say no laugh at them for not having enough skill to run a bead. You could use blue magic exhaust metal putty....it seems to do some good size cracks at least from what ive seen
Old 02-02-2013, 05:17 PM   #24
joey18's Avatar
One guy said he couldnt do it because it was cast and one said it would only last 2 weeks so he'd rather replace it.. i think they are trying to get me to spend more
Old 02-02-2013, 05:21 PM   #25
It wouldn't last...they are telling the truth
Old 02-02-2013, 05:29 PM   #26
deadsp0t's Avatar
++^^ exactly, they are steering you toward already permanent, lasting solution.. As a business owner they don't wanna don something half assed like weld up a manifold vs replacing it for just a little more money and know they made a repair that's not coming back to bite or haunt them.
That's unimpressive
Old 02-02-2013, 05:31 PM   #27
joey18's Avatar
My situations is a temp. Is what i want so next month o can afford headers... i cant afford to replace them at the moment
Old 02-02-2013, 05:33 PM   #28
deadsp0t's Avatar
Then your best option is to use what slowsix suggested or JB Welb or some other band aid until you can get some headers. You can probably get the ones lowFlyn suggested on eBay pretty damn cheap.
That's unimpressive
Old 02-02-2013, 05:42 PM   #29
GDogg08's Avatar
Money is on exhaust leak, at worst maybe a lifter but i really doubt that.
GDogg08 is offline   Reply With Quote
Old 02-02-2013, 06:00 PM   #30
joey18's Avatar
How would you tell the difference?
Old 02-02-2013, 06:20 PM   #31
GDogg08's Avatar
Well you can feel an exhaust leak, if its a lifter you will hear a tapping sound, grab a screw driver, put the steal side on the valve cover, and put the plastic side right up to your ear. Then just listen and see if you hear wear noises inside, you could always go to the other valve cover and see if it sounds the same or different.
You can do this trick on anything really and hear inside better.
Old 02-02-2013, 07:24 PM   #32
austinknoll's Avatar
You don't need new headers. Temporary solution is go to a scrapyard and pul one out of an old mustang. While you're at it find a tube to move the ac drip away from the manifold
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 02-02-2013, 07:33 PM   #33
joey18's Avatar
---------- Post added at 09:33 PM ---------- Previous post was at 09:31 PM ----------
Yeah that would probably be a good temp fix. I eventually wanna get headers but a little after i start paying for the car... i havent evn made my first payment:/
Old 02-04-2013, 09:19 AM   #34
joey18's Avatar
So i got under and did some looking and it looks like where the exhaust piping meets the header it is loose.. enough where you can shake it around.. so i think its that
Old 02-04-2013, 09:49 AM   #35
It's the weld where the collector meets the log on your manifold. I'll put money on it.
12:57 AM
