Best plugs for stock - Mustang Evolution
Old 07-09-2008, 05:39 PM   #1
Foxone's Avatar
Just picked up an 04 3.8. Just wondering what plugs would be best?
Foxone is offline   Reply With Quote
Old 07-09-2008, 07:40 PM   #2
Re: Best plugs for stock
motorcraft or autolite
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 07-09-2008, 08:16 PM   #3
Spark Plug's Avatar
Stock Ones
motorcraft or autolite for sure
Spark Plug Racing- "If it Breaks It Was Meant To Be Upgraded
2003 Dodge Ram HEMI
2008 Suzuki Kingquad 750 4x4
Spark Plug is offline   Reply With Quote
Old 07-09-2008, 08:57 PM   #4
motorcraft!!! had an autolite come apart in the cylinder one time.
SimplyOrange is offline   Reply With Quote
Old 07-09-2008, 09:17 PM   #5
Motorcraft or autolite, had a hard time finding the motorcrafts for some reason though.
Old 07-09-2008, 11:02 PM   #6
Send a message via AIM to VCS_SSSTANG
As long as its not Bosch plugs..
VCS_SSSTANG is offline   Reply With Quote
Old 07-10-2008, 12:08 AM   #7
well autolite builds the plugs for ford. you can sit an autolite plug next to a motorcraft and they look almost the same.
Old 07-10-2008, 12:53 AM   #8
btw i got autolite xp plugs in my car now and it seems to be running pretty good. i was getting better mpg until every freaking gas station put E10 in their gas and now i'm back to where i was. anyways i know ford uses autolite and chrysler uses champion but who makes the plugs for gm? i know about a week ago i picked up some new plugs for my moms trailblazer and the pack said made in japan and it kinda looked like some NGK plugs i've seen.
Old 07-10-2008, 01:01 AM   #9
Scorpion1's Avatar
IIRC GM uses Champions or autolites. Ive seen both.
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 07-10-2008, 07:19 AM   #10
Spark Plug's Avatar
gm is normally ac delco, i know some new chrysler stuff is bosch from the factory.
2003 Dodge Ram HEMI
Old 07-10-2008, 07:20 AM   #11
stock OEM ones gapped correctly of course~ thats all you need.
Old 07-10-2008, 08:14 AM   #12
Danger Dude's Avatar
Autolite are the bomb. I would not use anything else unless it was motorcraft on a Ford. I believe the plug you had might have been dropped. The best thing you can do is inspect each plug before you leave. Never buy bulk packs from Wal-Mart. The abuse boxes go through when they unload the trucks is a horrifying. Check closely for any machine flashing or metal thats stick out inside the combustion chamber especially on the landing or flat area that the spark can jump to. I was on a dyno and between runs I installed new plugs and lost 5hp. So we took a thermal reading and one was much colder so we pulled that plug out and a tiny piece of metal was sticking up on the landing opposite of the side electrode and once I filed it down we gained back 8 hp.
Quite honestly I have throughout the years tried every type of spark plug, V groove, U groove, Splitfires, Super Duper ultra Extreme Platinum tips, Delco, Champion, Accel and every type in between and I can honestly I have never seen any magic performance or mileage improvement that a new stock plug whould nbot have accomplished when changing out old worn out plugs. The best advice I can give is either use stock plugs or motorcraft in Fords. Honestly Bosch aftermarket stuff is junk. They make really good OEM equipment but not aftermarket stuff and stay away from high dollar plugs which are only taking money out of your pockets just as oil filters that cost 10+ dollars. A complete waste of money on something that cost less then $5 does just as good a job or better.
Ford-Motorcraft or autolite
Chevy-Delco or autolite
Jap cars, bikes or Outborad motors- Manufacturer brand , Denso, NGK or autolite
European cars- Manufacturer brands which are mostly Bosch or Bosch
Old 07-10-2008, 08:29 AM   #13
Herbstang's Avatar
3.8s came from the factory with a 42 heat range plug, this is a very hot plug, some vehicles will even ping from the factory.
Recomendations: NA 3.8s 22 heat range plug
Power Adder 3.8s 22 heat range plugs
3.8s running very high boost, a large nitrous shot, or a high compression ratio may want to run a colder 12 heat range plug.
Motorcraft AGS-12C Copper Spark Plugs
Recommended for high boost, large nitrous shots, or high compression ratio NA vehicles.
Gap before installation.
Power Adder gap at .035"
NA gap at .054"
12 Heat Range.
Old 07-10-2008, 08:39 AM   #14
it could have been a freak accident, i always check my plugs before install.the electrode fell off of one into my cylinder, and another one had the ceramic shield over the electrode bouncing up and down causing a misfire... could have been a freak thing.i have cold heat range autolite on my nitrous right now, im just really weary of them.
Old 07-10-2008, 08:46 AM   #15
Herbstang's Avatar
I hijacked that info from VMP I'm currenty using Motorcraft AGS-12C Copper Spark Plugs which VMP suggested
Old 07-10-2008, 11:04 AM   #16
NA gap at .054"
12 Heat Range.
Most of the guys running boost run tr6 gapped @ 30.
Old 07-11-2008, 07:35 PM   #17
wallysan27181's Avatar
Send a message via Yahoo to wallysan27181
AHMEN from the back row!!! I wasted time and money, not to mention how I felt when I drove my 97 and it missed and hesitated. I joined this site and then found out about BOSCH......I changed them to Autolites and she runs like a top now! I will never use BOSCH plugs again in my Pony. Just wish I had found this site sooner.......:thumbs2:
wallysan27181 is offline   Reply With Quote
Old 07-12-2008, 04:51 PM   #18
Bosch works good in euro cars i guess but if i owned a bmw or something like that i still think i'd go with a different brand after all the Bosch stories.
Old 07-12-2008, 05:32 PM   #19
1234's Avatar
If im not mistaken autolite and ford have a thing with eachother. I worked in a part store for a few years. We had tons of reps come trough there. They all told me they work with Ford to make their plugs.
E3 Spark Plugs ? occhopperman27 New Member Introductions & Greetings 6 06-19-2009 04:03 PM
best plugs bosscityboy86 1996-2004 Mustang GT 13 09-12-2006 06:11 AM
Wanted: Stock coil springs and stock mufflers for '96 GT inaba116 Mustang Parts for Sale and Wanted 6 02-15-2006 09:19 PM
Stock 03/04 Cobra vs Stock LS1 PureVenom The Bar 46 05-08-2005 05:41 PM
Installing a stock V8 on my stock V6 EXHAUST mrshoss97V6 Pre-2005 V6 Mustang 3 06-30-2004 12:43 PM
02:32 AM
