manual transmission oil change - Mustang Evolution
Old 02-02-2013, 12:34 PM   #1
Torchredfrankie's Avatar
My stang just hit 83,xxx is it time for its transmission oil change?
Torchredfrankie is offline   Reply With Quote
Old 02-02-2013, 01:36 PM   #2
Mustangman92's Avatar
I did mine at 60k
Mustangman92 is offline   Reply With Quote
Old 02-02-2013, 01:36 PM   #3
Venomouz831's Avatar
I just changed mine at 73k
)02 Gt, Founder of WE2G
Old 02-02-2013, 02:46 PM   #4
What oil did you guys use and how much?
Old 02-02-2013, 02:52 PM   #5
I used ford mercon oil what they reccomend. And i believe it was like 4 quarts
Old 02-02-2013, 03:06 PM   #6
1slosix's Avatar
3.25 qrts of trans fluid...i reccommend swapping 1 qrt of fluid with a qrt of syncromesh
carving corners like a boss
Old 02-02-2013, 03:19 PM   #7
[/COLOR]Will royal purple work? I got it in my engine.
Old 02-02-2013, 03:20 PM   #8
1slosix's Avatar
yes RP will work if you can find it in the right fluid type
Old 02-02-2013, 03:22 PM   #9
Do you know the weight our 6s use?
Old 02-02-2013, 08:59 PM   #10
GDogg08's Avatar
it should tell you on your dipstick what kind it calls for, make sure you change the gasket and filter while your changing the fluid.
GDogg08 is offline   Reply With Quote
Old 02-02-2013, 11:44 PM   #11
1slosix's Avatar
he won't need to change any gaskets or filters for a 5 speed flush and fill...if it's as easy as my GT was then just drain it from the drain plug...pop off the shifter and fill from the top after you've put the drain plug back in
Old 02-03-2013, 12:27 AM   #12
GDogg08's Avatar
yeah if its a 5 speed, but he didnt specify what type of trans it was. So better safe to throw that out there for an automatic trans
Old 02-03-2013, 12:30 AM   #13
1slosix's Avatar
Since he was asking weight i can only assume 5 speed since an auto is just a fluid type. But yes if its an auto id spend the $15 on a filter and gasket kit
Old 02-03-2013, 12:33 AM   #14
+1
09:08 AM
